oil cooler lines?? - Defender Source
Old December 3rd, 2004, 04:37 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
oil cooler lines??
Is this a easy job for someone slightly handy under the hood?
Old December 3rd, 2004, 05:40 PM
If you can thread ends on a garden hose, you can do this job. Access is cramped, but the hardest thing is disposing of the oil.
Old December 3rd, 2004, 07:54 PM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
Jim - How long should this take a competent mechanic? I'm taking my truck to the local shop on Mon. for this.
Old December 3rd, 2004, 08:12 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
15 minutes!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 3rd, 2004, 08:25 PM
It shouldnt take a comp mech more than an hour or so. I really dont know what a Rover dealer or generic estimation guide list as the appropriate amount of time to be billed.
The man who drives a Defender equipped with 37-inch tires is right though, if you came by the house, we'd do it up quickly and you'd be right back on the road.
Old December 3rd, 2004, 10:16 PM
4WD-90's Avatar
4WD-90
Christopher Stanish
1994 defender 90
Smile
Hey Richard, It seems like a simple enough job. I could offer up some help. If you need a hand, let me know. Where "just outside of philly" are you?
Old December 4th, 2004, 10:20 AM
PT94D90's Avatar
PT94D90
Phil
Thanks guys. Wish I lived a little closer, Jim.
Old December 4th, 2004, 10:45 AM
Campbell's Avatar
Campbell
Rich Campbell
last time I tried to get my garden hose on I couldn't do it. Do they screw on? maybe thats what I did wrong.
I might try this. I wasn't sure if you need any specific tools to do the job other then a few hand tools. drain the oil, put on the new hoses and fill the oil. I think I can handle that.
Christopher, I live in the East Falls area.
rich
Old December 4th, 2004, 05:47 PM
marcva
Marc van Aperen
1984 90 300 TDi
Just make sure you get the right hoses.
They sold me waterhose and I had to rebuild my engine.
(lost the oil, etc. , etc.)
Rgds.
Marc
Old December 5th, 2004, 08:04 PM
bd90
94 Arles Blue #1644
After removing mine, I took em to the local hose shop and asked for some SS braided hoses made up ($100+). The guy talked me into letting him cut off the old hose and install some pretty standard rubber hose with clamps ($10). He said they'd last longer than the 90. But even if they didn't, I would only need to buy another section of rubber hose and push it on and tighten the clamps without having to get to and remove the screwed connections. Also, he recommended keeping the outside of the hose clean because they disinigrate from the outside in.
Old December 5th, 2004, 08:40 PM
Are you joking? You mean standard hose clamps? Granted the oil system is not operating at extremely high (hydraulic-like) pressures, but I'm not willing to trust my engine to hose clamps. The cooling systems only uses hose clamps, but If coolant spews out everywhere ithen everything gets wet. If oil spews out everywhere, then everything catches on fire.
Old December 12th, 2004, 02:29 PM
bd90
94 Arles Blue #1644
Not joking. I trust my setup lasts longer than your original LR hoses. Also, I seriously doubt oil spewing comes from a bad hose clamp... that's a leak. Spewing oil comes from hose rupture.... the kind you get from the LR part. I should know... it happened to me.
Old December 12th, 2004, 03:18 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Well, it should theoretically be fine if he used high pressure hose and high pressure clamps. Modern EFI systems use fuel lines in the same pressure range, if not higher. If they are high pressure clamps and hose, he should be fine.
Might be something worth looking into.
-Hans
My oil line fix
My 100k stopped odometer fix
oil cooler lines CHRIS C Defender Technical Discussions 39 December 21st, 2004 11:30 PM
Oil cooler lines revisited rover4x4 Defender Technical Discussions 5 July 9th, 2004 08:40 AM
Stainless Oil cooler lines??? Neo Defender Technical Discussions 3 February 3rd, 2004 08:04 PM
