Oil cooler lines - Defender Source
Old February 25th, 2008, 10:51 PM
DieselVol
Van Bingham
none
Oil cooler lines
I was recently told by a seller that the oil cooler line issue is not an issue on the '97's. Any truth to that? Any '97 major issues that I do need to consider since the search seems to have narrowed to a '97 or nothing? Thanks.
Old February 25th, 2008, 11:02 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
They are an issue, but not a big one. Just replace them every so often. The only issue with the 97's is that they are made by Land Rover. Other than that, your good.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 25th, 2008, 11:15 PM
TND90's Avatar
TND90
Keith Allen
94 d90 ST
Van,
The 97 lines need to be replaced just like the others as they are 10yr. plus old vehicles and the factory lines will rot over time. There are a few minor differences beween the 94/95's and the 97's, however the fact remains that the lines should be changed and perferably replaced with S/S lines.
I live in the Memphis area and would be happy to show you my updated lines. I got them done locally for about $120.
Keith
"There is no normal life Wyatt, there's just life."
Doc Holliday
Old February 26th, 2008, 01:44 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
$125 to replace them..... or the possibility of having the truck burn like pot at a Grateful Dead concert.
Your call.
My oil line fix
My 100k stopped odometer fix
Old February 26th, 2008, 06:28 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Just use caution when replacing lines on '97's as the fittings thread into the front timing cover instead of the filter housing as on the older motors. The front cover end of the lines use a very low torque (not sure what off the top of my head....read the fawkin manual) and if over tightened will crack the front cover, which is fairly expensive to replace.
Had to repair this for more than one handy home mechanic, and even "factory trained" techs have fawked it up.
Matt Browne
Old February 26th, 2008, 09:22 AM
DieselVol
Van Bingham
none
Keith,
I really live in Lakeland, just over the hill from you. We've all been programed to put Memphis on everything for so long that we just keep doing it. Thanks for the offer.
oil cooler lines CHRIS C Defender Technical Discussions 39 December 21st, 2004 11:30 PM
Oil cooler lines revisited rover4x4 Defender Technical Discussions 5 July 9th, 2004 08:40 AM
Stainless Oil cooler lines??? Neo Defender Technical Discussions 3 February 3rd, 2004 08:04 PM
