Oil Cooler Line Parts List - Defender Source
Old November 1st, 2007, 09:45 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I have a '94 with the 20mm fittings on the oil filter mount. It seems like the parts lists for replacing the oil cooler lines say I am SOL.
Does anyone out there have a good parts list for the larger size fittings? I plan on just ordering everythng from JEGs or Summit.
Thanks!!
Semper Fi!
Old November 1st, 2007, 09:51 AM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
I would see if loykd has anymore kits. the work has already been done and the kits were cheap. I believe he is in VA too.
Old November 1st, 2007, 11:49 AM
Wolf Fabrication
Sterling Archer
'08 D3
Thanks, I did contact him. He still needed to order a few more parts....
Semper Fi!
Old November 1st, 2007, 12:07 PM
themaxx's Avatar
themaxx
Ade
94 ST
I have new ECR oil lines that I didn't put on my 94, if you want them $205 shipped.
Old November 1st, 2007, 01:16 PM
Wolf Fabrication
Sterling Archer
'08 D3
Aren't the ECR lines for the 18mm fittings? They claim they don't have a 20mm kit yet.
I'd be interested if you do have the 20mm kit.
Semper Fi!
Old November 1st, 2007, 01:29 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
I need a 20mm kit also. Please post a source if you find one. All the kits I have found so far are the 18mm.
Gary
Old November 1st, 2007, 01:53 PM
Wolf Fabrication
Sterling Archer
'08 D3
Trailhead 4X4 out west (probably near you!) has the 20mm kit. I think they wanted $285 for their kit.
Semper Fi!
Old November 1st, 2007, 01:56 PM
themaxx's Avatar
themaxx
Ade
94 ST
Fortunately for you, I do have the 20mm kit! I ran into the same issue with my 90, a friend here on this board made the 20mm fittings. Apparently 20mm is NOT a standard fitting that you can find.
Here's a pic, it's made out of steel. If he want's to make more, I'm sure he'll post his services or you could go to a hydrualic shop and have a fitting made.
Trailhead4x4.com is in the midwest (Cleveland, Ohio). The guys does amazing work!
Old November 1st, 2007, 02:08 PM
bjf's Avatar
bjf
barry f
94 ST #395
I got my set of stainless from trailhead. Great set. Couple of tips people should know. Even if you use stainless there is still a teflon hose inside it that is susceptible to heat so despite what people say you still need to be careful about heat and fire. Four Oaks that did my install, wrapped the lines from top to bottom in heat shield so if for some reason there was a leak it would force it downward and not on the manifold. Also when installing sometimes it takes some adjusting on the lines so it doesn't leak. Oh and mine is 20mm. Most 94s are.
Old November 1st, 2007, 02:10 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
So those are just adapters to get to the 18mm size fittings, then you use the normal 18mm setup? If that is true I could use a set of the adapters if they are for sale. I have found all the other parts, just not any 20mm-18mm adapters like the ones pictured.
Gary
Old November 1st, 2007, 02:14 PM
Wolf Fabrication
Sterling Archer
'08 D3
[QUOTE=themaxx]Fortunately for you, I do have the 20mm kit! I ran into the same issue with my 90, a friend here on this board made the 20mm fittings. Apparently 20mm is NOT a standard fitting that you can find.
I will most likely take your kit. Can you tell me what it comes with and possible post or email me a pic?
my email is slickwillys@gmail.com
Semper Fi!
Old November 1st, 2007, 02:37 PM
TND90's Avatar
TND90
Keith Allen
94 d90 ST
Another option you might want to consider. Remove the factory oil lines, take them to a racing shop (i.e. Stock car, funny car, drag etc.) and ask them to cut the old rubber lines off the fittings and replace them with s/s flex lines. The guy I ran accross locally even put disconnects between the fittings and lines so they could be easly replaced in the future. They even cleaned the fittings and powdercoated them black. All of this took a day and $120.00.
Just a thought. Good luck.
KA
Old November 1st, 2007, 04:08 PM
themaxx's Avatar
themaxx
Ade
94 ST
You can see the lines on ECR's website.
Old November 1st, 2007, 05:43 PM
Wolf Fabrication
Sterling Archer
'08 D3
themaxx: PM/email sent
Semper Fi!
Old November 1st, 2007, 05:52 PM
vesparover's Avatar
vesparover
brian bertolini
What would happen if you just removed oil lines?
Why not just remove the problem and be done with it? Any adverse affects?
Old November 1st, 2007, 05:53 PM
themaxx's Avatar
themaxx
Ade
94 ST
FYI: Spoke to Eric at Trailhead4x4, he has a few oil cooler lines with the 20mm fittings in stock!
Old November 1st, 2007, 06:00 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
If you remove the oil lines, you also have to remove the sandwich plate..... or you're just going to pump all your oil onto the ground within a few seconds and then buy a new engine.
though removing the sandwich plate isn't hard at all, just that you have to remember to do it.
-Hans
My oil line fix
My 100k stopped odometer fix
Old November 1st, 2007, 06:29 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yeah, I checked with Trailhead, but they want $285 plus shipping for the kit, just like ECR. I was hoping to build the lines myself and save some $$.
Semper Fi!
Old November 1st, 2007, 07:08 PM
themaxx's Avatar
themaxx
Ade
94 ST
Email sent!
Old November 1st, 2007, 07:56 PM
I had the same problem and just had mine rebuilt locally here in Chantilly. I can't recall the name off the top of my head but it's a hydraulic/fitting shop just inside Rt50 and Rt28. I think I got them done for under $100. I plan on doing it again for the lines that came with my "new" engine. I can dig up the name if you want to give them a try.
charles
part, parts
Oil Cooler Line Orientation Question dnewman9 Defender Technical Discussions 3 April 9th, 2011 06:24 PM
Oil Cooler line kit! Eric Siepmann Defender Technical Discussions 22 February 20th, 2007 10:09 PM
old oil cooler line Abrooks Wanted 1 March 17th, 2004 06:52 PM
