Oil Cooler line kit! - Defender Source
Old December 10th, 2005, 12:36 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Found this surfing the www. Located in OH they sell an oil cooler line kit. Looks good. Might have to call them...
http://www.trailhead4x4.com/18401.html
Old December 10th, 2005, 12:50 PM
not bad looking. I wonder what they cost
Old December 10th, 2005, 01:14 PM
Follow-up on the Discoweb........... Kind of funny.
Discoweb Thread
Old December 10th, 2005, 03:58 PM
jstrong98's Avatar
jstrong98
Jon Strong
I didn't see a price ? How much ??
JS
Old December 11th, 2005, 02:48 PM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
He must be new to the Rover Game. I used to manage that area for FedEx and I never have seen him.
Matt...
1995 D-90
1967 Series IIa
Old December 30th, 2005, 06:34 PM
Antonios
Antonios Hadjigeorgalis
No more
I just checked ...$279 for the oil line replacement. That sounds a little steep. The kit looks like it replaces the fittings on the radiator with some standard type fitting. Same for the oil filter plate. If that's the case I would think the parts are pretty cheap.
Anybody know the thread size of the radiator plug and the plate fittings?
I'm thinking I might just remove the oil cooler lines & sandwich plate then re-install the oil filter. Then I can drive my truck to go shop for proper fittings.
Would driving without the oil cooler in place put me in danger of overheating?
Miami, FL
Old December 30th, 2005, 06:41 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I think you'd only be in danger of overheating if you were towing a loaded trailer across death valley. I have been running without the oil cooler for a month now. Also, the 87-88 classics never had one and Land Rover deleted them from the D2s in 2004...they found they didn't need them. I'm thinking about leaving it off permanently. I also gained about 7psi of oil pressure without it.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old December 30th, 2005, 06:46 PM
Antonios
No more
Now that sounds like a REAL solution! Thanks for the info Rob.
Miami, FL
Old December 30th, 2005, 07:02 PM
Grover's Avatar
Grover
Oil Cooler Lines
I just had my oil cooler lines re-fitted with stainless steel braided lines by Ohio Hydraulics. I used the original tubes from the radiator and the banjo bolts from the oil filter plate. I had the old rubber tubes cut off and had the steel threaded fittings welded to both the tubes and the banjo bolts. I wanted to make this modular so I can replace the hoses if needed. All this took about an hour to fabricate and cost $100.
1995 D90 ST
Name:	Oil Cooler Line Send.gif
ID:	4697   Click image for larger version
Name:	Oil Cooler Line  Return.gif
Old December 30th, 2005, 09:03 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Only concern I have about that setup is the radiator fittings, mine seem to be pretty much siezed into it, and I don't want to risk busting something
My oil line fix
My 100k stopped odometer fix
Old December 30th, 2005, 10:55 PM
artm
Arthur Maravelis
97 SW
Get a real cooler and ditch the built-in one. Then you plumb into it with generic fittings and lines. Do the same for the tranny.
But if you can gain 7 lbs of pressure without it this may be preferred. Is that at idle? I guess installing an oil temp gauge and monitoring it for a while may be worth it.
Old December 31st, 2005, 12:29 PM
Grover's Avatar
Grover
Oil Cooler Lines
The fittings going into my radiator were seized, however I could still remove the steel tube from the seized fitting.
Old January 2nd, 2006, 05:19 PM
scoloco's Avatar
scoloco
'94 D90 ST
Where and how would be the best place to tap in for an oil temp guage?
Old January 2nd, 2006, 05:28 PM
Grover's Avatar
Grover
What is the normal operating oil temperature and pressure?
Old January 2nd, 2006, 06:53 PM
Roadsiderob
Robert Dassler
1994 D90
I'd weld a bung to the side of the pan...or I've got a pan from a classic that has a bung already for the level sender...that could probably be used easily.
I've no idea what temp the oil normally runs, pressure spec is like 26psi at 2500rpm at operating temp. On the older engines you can boost the pressure a bit by shimming the relief valve spring with a washer.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old January 2nd, 2006, 07:51 PM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
Grover,
Where is Ohio Hydralics? Where are you located?
Matt...
1995 D-90
1967 Series IIa
Old December 18th, 2006, 03:05 PM
Grover's Avatar
Grover
Originally Posted by Dfndr90
Grover,
Matt...
Matt,
A little late (almost a year) but Ohio Hydraulics is located in Sharonville Ohio, just north of Cincinnati. The made my oil cooler lines. They are a heavy equipment hydraulic supplier/fabricator. If you want some pix, I will email them to you. Also, I am located in Cincinnati...
Happy Holidays!
Old February 17th, 2007, 10:39 AM
Shake
Bob Hanson AKA Two-Socks
Red 94 D-90 #428
It's been a few months. Anybody have a verdict? Rob's opinion means a lot to me. Why go through the expense of new lines when we can eliminate the problem all together? Fire?Are you kidding?
Rob - How many shop hours is it to remove the oil cooler and set up the engine/radiator to run without it?
General question: Why is a boost in oil pressure good on a 3.9 engine? What happens if you add a supercharger? Any impact?
"I ain't lost!!, ain't NEVER been lost...<Scratching head>Been a might confused fur a few hours...but I ain't never been lost."
Old February 17th, 2007, 10:48 AM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
removing the oil cooler lines seams like a good solution for me in the temporary, has anybody been running like this for awhile? i don't tow anything and i won't be getting much wheeling in the near future...
otherwise anyone have the info on the place in ohio, i'd like to order the steel braider portions.
Old February 17th, 2007, 01:44 PM
Grover's Avatar
Grover
http://www.ohiohydraulics.com/
Any industrial hydraulic shop should be able to make the lines. If you want pix of my set-up, let me know...
Cheers...
kit
Oil Cooler Line Orientation Question dnewman9 Defender Technical Discussions 3 April 9th, 2011 06:24 PM
my last oil cooler line ? rover4x4 Defender Technical Discussions 9 February 3rd, 2006 01:27 PM
old oil cooler line Abrooks Wanted 1 March 17th, 2004 06:52 PM
