Oil Cooler line kit! - Page 2 - Defender Source
Old February 17th, 2007, 03:55 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Originally Posted by Shake
It's been a few months. Anybody have a verdict? Rob's opinion means a lot to me. Why go through the expense of new lines when we can eliminate the problem all together? Fire?Are you kidding?
Rob - How many shop hours is it to remove the oil cooler and set up the engine/radiator to run without it?
General question: Why is a boost in oil pressure good on a 3.9 engine? What happens if you add a supercharger? Any impact?
If you can change you own oil, your can remove the oil cooler. It is straight forward. High mileage engines could use extra oil pressure.
JP
legend in my own mind
Old February 17th, 2007, 04:18 PM
Antonios
Antonios Hadjigeorgalis
No more
I removed mine last August and in September drove from Miami to Baltimore in two days with the inside of the truck fully loaded, the back end was sagging. 70-80mph the whole way with the temp needle right in the middle. Removing the oil lines was no more difficult than replacing the oil filter. 15-30 minute job. Take it off and try it. If you think it runs hotter get the lines fixed at a hydraulic shop and put them back on.
Miami, FL
Old February 20th, 2007, 10:09 PM
Shake
Bob Hanson AKA Two-Socks
Red 94 D-90 #428
JP
Thanks, Pendy. Spoke with Rob on the phone. Looks like all it takes is a 30mm Hex and a few minutes. Have 135K miles on my truck.
Also have input from Solihull. Apparently ECR has a kit for $200 but I haven't checked it out yet.
kit
Oil Cooler Line Orientation Question dnewman9 Defender Technical Discussions 3 April 9th, 2011 06:24 PM
my last oil cooler line ? rover4x4 Defender Technical Discussions 9 February 3rd, 2006 01:27 PM
old oil cooler line Abrooks Wanted 1 March 17th, 2004 06:52 PM
