oil cooler line flare and $50 hose rework - Defender Source
Old June 14th, 2006, 12:45 AM
artm
Arthur Maravelis
97 SW
Pic below is for a 110 Tdi.
1. I found a place in Mass that will redo the oil cooler hoses for $50. New, much better hose attached with ferrules to the existing pipe so it's serviceable. Marlboro Hydraulic Hose & Supply, 508-485-3337, ask for Wayne.
2. Only problem, for my 110 lines at least, is that one of the lines near the adapter ("A" in the pic) does not have the 1-inch length of pipe required by this shop.
3. So, I have to make up a short line with the flair ("B" in the pic) so this shop can then fit the hose. Does anyone know what type of flare this is? It's as if the pipe has been squashed to make a compression-type fitting.
Stock springs, oil cooler lines Bozman For Sale - Parts 5 March 26th, 2008 09:33 PM
Near New Stock Oil Cooler Lines Wolf Fabrication For Sale - Parts 0 November 15th, 2007 04:53 PM
replacement oil cooler lines Tdi artm Defender Technical Discussions 3 August 14th, 2006 06:34 PM
FOR SALE - Set of Used Oil Cooler hoses / window studs eric_besore For Sale - Parts 10 August 31st, 2005 02:18 AM
Viscous clutch part #ERC5708 brand new in box $50 draaronr For Sale - Parts 0 January 1st, 2005 11:21 PM
