Oil Cooler Line Delete Thoughts - Defender Source
Old January 28th, 2013, 02:34 AM
Surf90's Avatar
Surf90
C.S.
1989 Defender 110 200tdi
What are folks official thoughts on just straight up deleting the oil cooler lines? I know a few guys have done it. Has anyone done it and regretted it?
I'm changing the oil in my 90 tomorrow for the first time and need to address the lines in the process.
Thanks!
Edit: By regret it, I mean, has anyone suffered adverse effects of removing them? Overheating, etc? I know they can be re-added after removing.
Old January 28th, 2013, 07:24 AM
Thanks!
I don't know anyone that deleted them however it doesn't seem like something you'd want to to try and find it wasn't a good idea. The consequences of getting this wrong would be a dead engine.
Lots of people have overheating problems with these engines, removing oil cooling would contribute to that.
Old January 28th, 2013, 07:48 AM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
Thanks!
I know a Rover V8 isn't a high strung flat six, but one of THE most important things in a P-car is keeping a plentiful supply of cool oil.
Maybe if you lived in Alberta or Alaska you could get away with it, but imagine the one time you got stuck in traffic, or decided to tow something........
I could understand deleting them if they were unobtanium, but they're readily available and not prohibitively expensive.
I realize I'm not answering your original question because I don't have any experience with deleting a cooler, but thought I'd cast my vote for keeping it. I'd hate to see you regret it if the circumstances aligned and you toasted your lump.
Old January 28th, 2013, 08:17 AM
There is a reason they exist. Do not disturb the Force!
Old January 28th, 2013, 09:06 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Deleting them pits you against the engineers in Solihull. We all know how incompetent they've been at times, but better safe than sorry here. An upgrade to stainless lines is a relatively cheap mod for peace of mind.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old January 28th, 2013, 09:34 AM
Kill them. No worries.
Old January 28th, 2013, 09:54 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
I see both sides but I tend to hug caution when considering stuff like this, for example my 90 has had the sway bars removed...I'm ok with that because tight cornering in the 90 isn't an option anyway. In the matter of cooling...the cooler the better. I upgraded mine, they work and I dont have to have any future consideration for them.
Old January 28th, 2013, 10:56 AM
The same engine in other models did not have the cooler lines. Personally I'm not worried much about my oil temp in a v8 like I would be on a tdi where is running through a 1200 degree turbo. If you change your oil every 5k or less imo there is only upside to deleting the lines.
Old January 28th, 2013, 10:59 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I removed mine, but also added a huge 5 core radiator. If you increase the efficiency of cooling through the radiator then you can removed them without any effect.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old January 28th, 2013, 11:08 AM
(Overheard at Solihull....) Hey 'oo's the bloody bloke what ordered 'ese 'ere tree 'undred thousand oil cooler adapters?
Wernt me, laddy.
Well, what the 'ell r we s'pose t'do wit these 'ere things?
Well, sez me I say we put 'em on ev'ry bloody V8 and jack up the price 'nother 500 quid, eh wot?
Bloody good show old chap! Up fer a pint are we?
Old January 28th, 2013, 11:09 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
i considered killing them too but it seems these engines don't manage heat very well to begin with so $200 of insurance is worth keeping them for me.
i think external oil cooler were factory options on early 110's and RR's. i have a dealer spec sheet for an 83 110 i bought that shows external oil cooler and power steering as factory option the original owner opted for. somewhere along the way LR may have decided it was goo insurance too. probably overkill in most applications still.
Clay
RobTheGob's Avatar
RobTheGob
Rob
1963 IIa 88 & 1995 NAS D-90 SW
I'm sure the oil cooler is serious overkill from an engineering standpoint. If you have a 130 running a small PTO sawmill in the Amazon - I'd worry about removing it. But I think a light duty 90 running in a mild climate will be fine - for an indefinite amount of time.
I also found that the oil pressure light goes out almost instantly without the lines - with the lines in place, I could count to 3 or 4... I suspect that negates any issues with slightly cooler oil. I'd like to install an oil pressure gauge to see what the pressure is actual doing...
Having said that - mine have only been off for two weeks (winter weeks - never higher than 8 degress C) and I'll likely reinstall them in the spring. Since my brother-in-law works in hydraulic fabrication - I can get very heavy duty lines made for cost.
Old January 28th, 2013, 11:22 AM
I personally think the oil cooler should be left in.
People spend hundreds of dollars putting aftermarket oil coolers on their trucks trying to make them "expedition ready". Defenders came with them stock. For extended driving, idling, and pulling heavy loads in high temperature climates, oil coolers can drastically extend oil life. It's a bit like why Z06s use dry sumps. Makes absolutely no sense for 99.999% of the driving that people do, but under specific circumstances, they may make a critical difference.
If you have oil pressure problems with the oil cooler lines installed, you may have some serious engine issues, or you're running some 5W40 or some other way-too-thin oil.
Old January 28th, 2013, 11:31 AM
RobTheGob's Avatar
RobTheGob
Rob
It's only at start up and I'm not sure what viscosity it is... The previous owner put it in - recently by the colour of it...
It never gets much below freezing here - so I'm sure I can run something on the upper end of the scale.
Old January 28th, 2013, 11:34 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Wernt me, laddy.
Nice.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old January 28th, 2013, 11:35 AM
Bill Larson
Bill Larson
Wernt me, laddy.
God...I can just see that right now! lol...
Old January 28th, 2013, 11:46 AM
Streaky's Avatar
Streaky
Alden
1994/D90 NAS
Deleted mine 2 years ago. No issues.
I have a stock radiator and my thermostat stays right in the middle. I drive it year round, 'tho the summers here aren't nearly as hot as other places.
Old January 28th, 2013, 11:54 AM
You can go around and around all day long on different opinions here just by searching "oil cooler remove" and weigh the good with the bad and the indifferent. Personally, I bought Trailhead 4x4 stainless steel oil cooler lines and had them re-routed away from the manifolds.
Old January 28th, 2013, 12:24 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
I'll leave it attached.
But have you ever looked inside the radiator tank?
I swear it's really a "coolant heater" instead of an "oil cooler".
Old January 28th, 2013, 12:27 PM
bjf's Avatar
bjf
barry f
94 ST #395
I went the trailhead route too. Just get a set. Rovers might be designed like shit but anytime I have tried to make them better they became worse. Case in point getting a recored radiator. It didn't cool properly. As soon as I got a new stock one everything was great.
ht
Oil Cooler Line Orientation Question dnewman9 Defender Technical Discussions 3 April 9th, 2011 06:24 PM
my last oil cooler line ? rover4x4 Defender Technical Discussions 9 February 3rd, 2006 01:27 PM
old oil cooler line Abrooks Wanted 1 March 17th, 2004 06:52 PM
