Oil Cooler Line Delete Thoughts - Page 2 - Defender Source
Old January 28th, 2013, 01:36 PM
Surf90's Avatar
Surf90
C.S.
1989 Defender 110 200tdi
So it looks like my lines have been wrapped with something at some point. Are they still super sketchy??
Old January 28th, 2013, 01:42 PM
I deleted mine when I found the stainless line was possibly rubbing on an AC line. No ill effects, but I don't drive it much and I do run synthetic.
Old January 28th, 2013, 01:46 PM
Originally Posted by Surf90 View Post
So it looks like my lines have been wrapped with something sketchy.
Fixed it for you.
Old January 28th, 2013, 01:57 PM
Yes. Either delete them or upgrade. Just don't leave them stock. Many defenders have been car-b-q'd when these fail.
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I've run without my cooler lines for probably 20K miles. I've towed with it, driven it cross country and 4 wheeled in Moab, in july, all day, for a week straight on 3 separate trips. The engine temp (according the the gauge) is lower than it used to run with the lines in. I also put in a new radiator when I removed the lines so that certainly contributes but the car never overheats now. That needle sits left of center no matter the ambient temp. Cooler is always better but I have not seen any ill effects. I do not use synthetic oil but I do change every 3K miles. Temp wise the truck is the best it's ever been so I'm not planning on adding them back in until there is an overheating issue or there is some other issue forcing me to reconsider.
Old January 28th, 2013, 02:15 PM
Attachment 65374
that looks standard to me.
Old January 28th, 2013, 02:41 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Those lines look standard. replace 'em! Or remove them. I ran for months without lines, no change at all. Almost had a disaster story is, driving through town, pulling away from a stoplight, noticed a smell, then saw smoke coming out from under the hood!!! Luckily I pulled over in 1/2 a block and shut it down. There was a small pinhole leak shooting oil onto exhaust, and everywhere else.. No carbeque.
If I had the choice now, I'd get the stainless braided set and leave them in place. Cheap insurance.
~Steve
Old January 28th, 2013, 02:45 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Same here, was running with no lines for over a year, never had any problems except when my fan clutch when bad. I still plan on running with no lines.
Robert Deniro
Old January 28th, 2013, 04:54 PM
Surf90's Avatar
Surf90
C.S.
Thank you all for the advice. I really appreciate this forum and all of your wisdom. Invaluable stuff!! I am going to remove the lines for now and place am order for stainless. After reading through a bunch of stories I don't even want to drive it around the block with these lines.
Thanks fellas!
Old January 28th, 2013, 05:08 PM
Surf90's Avatar
Surf90
C.S.
So while waiting for new lines do I just:
1. remove the sandwich plate w/ lines attached
2. Screw oil filter on where sandwich plate was
3. Remove lines from radiator and plug holes
Old January 28th, 2013, 05:26 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Yessir
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old January 28th, 2013, 06:01 PM
No need to plug holes in the rad.
Old January 28th, 2013, 06:09 PM
Neil McCauley
Neil McCauley
I left mine open, would something bad happen to it?
Robert Deniro
Old January 28th, 2013, 08:57 PM
ini88's Avatar
ini88
Daniel Marcello
no need to plug them, but old oil may come out and get on stuff.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old January 28th, 2013, 09:05 PM
Yeah ... Like that doesn't happen as standard on a defender
Old January 28th, 2013, 11:00 PM
RobTheGob's Avatar
RobTheGob
Rob
1963 IIa 88 & 1995 NAS D-90 SW
My lines are still hanging in almost the same place as when they were attached... I've been putting Liquid Wrench on the radiator lines regularly - but the corrosion doesn't want to let go!! I don't want to damage the radiator.
Old February 5th, 2013, 04:33 PM
Surf90's Avatar
Surf90
C.S.
Got my new lines
Old February 5th, 2013, 05:34 PM
where is the like button?
Old February 8th, 2013, 01:51 AM
Surf90's Avatar
Surf90
C.S.
Closing out my thread with new shiniest / best looking part of my engine bay.
ht
Oil Cooler Line Orientation Question dnewman9 Defender Technical Discussions 3 April 9th, 2011 06:24 PM
my last oil cooler line ? rover4x4 Defender Technical Discussions 9 February 3rd, 2006 01:27 PM
old oil cooler line Abrooks Wanted 1 March 17th, 2004 06:52 PM
