Oil Change - Defender Source
Old July 7th, 2005, 04:18 PM
gtg067i's Avatar
gtg067i
Christian Shea
1997 Defender 90 Wagon
Oil Change
I went to the local lube place because I needed a quick oil change. When I pulled in there the guy said he didn't have the right wrench?? So I was curious, what is the correct size needed to drain? Probably a very simple, stupid question. Thanks anyways!
I require your largest, cheapest, most alcoholic brewed beverage.
Old July 7th, 2005, 04:24 PM
A big adjustable is what I use. And the oil filter is a very common size, same as a many Fords.
Old July 7th, 2005, 04:25 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
Nah. He has the right wrench. There is no special Defender wrench. I'll bet he's changed the oil in a 90 before and doesn't want to deal with the mess all over his garage.
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Old July 7th, 2005, 04:33 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I just use a big honking open ended wrench.... I think 1 1/4" but DON'T quote me on that.
-Hans
My oil line fix
My 100k stopped odometer fix
Old July 7th, 2005, 04:59 PM
jstrong98's Avatar
jstrong98
Jon Strong
1-1/8 " open end wrench for the drain plug. Be sure to replace the copper washer on the drain plug.
JS
Old July 7th, 2005, 06:05 PM
d901560's Avatar
d901560
Brian B
94 ST
I'll second the 1-1/8" open end. I recently bought one to keep in my tool box.
Old July 7th, 2005, 06:42 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
ah! now i know what i brought that wrench for,i keep seeing it in my tool box
3rd low and BOOT IT
Old July 7th, 2005, 07:38 PM
gtg067i's Avatar
gtg067i
Christian Shea
Thanks guys, he actually didn't want to change it because he said it was "too high" and he couldn't reach it and it would splash everywhere. Seems to me I'm just going to go buy the wrench and do it myself. Any recommendations on oil ? It's got 75,000 miles and also has the rimmer supercharger, if that changes anything. Full synthetic all the way but just wondering what you guys use.
Old July 7th, 2005, 08:19 PM
R. chili
Rob Childress
thats pretty bad, the dude works changing oil and doesn't want to get his shop dirty.? Then again I don't change oil as much as they do. I would take it somewhere else or do it your self. Just my 2$ worth.
Old July 7th, 2005, 08:22 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
You can reuse the copper washer. Heat it up to red hot then cool it in oil to anneal it. Works great. Make sure all surfaces are completely dry and clean and it won't leak.
Old July 8th, 2005, 10:32 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
If you hae a TDI, the wrench size is 17mm. As for oil, I would go with Mobil 1. I think they have great synth products.
Legend in My Own Mind.
Old July 8th, 2005, 12:32 PM
gtg067i's Avatar
gtg067i
Christian Shea
If I need to replace the copper washer, where do you guys get yours?
Old July 8th, 2005, 12:38 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
Warning: Cheap Bas$%^ reply for entertainment purposes only:
I almost never replace the washer. It's there to "keep your Rover from leaking". So, if it's not leaking, I don't change it. If it is leaking, how in the heck would I be able to tell anyway? You think a washer around the drain plug is leaking more oil than a oil pan gasket with over 90,000 miles?
Responsible Post:
You can get them from any Rover parts supplier at all.
Old July 8th, 2005, 05:38 PM
flip the washer and use a NAPA GOLD 1068
Old July 9th, 2005, 05:25 PM
gtg067i's Avatar
gtg067i
Christian Shea
Is this what you guys meant?
http://www.homedepot.com/prel80/HDUS...de=09-306251-2
Old July 9th, 2005, 09:57 PM
scoloco's Avatar
scoloco
'94 D90 ST
That should work - although I dont remember paying $20 for mine. While its a big bolt, it doesnt need 50million ftlbs torque.
Old July 11th, 2005, 01:13 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
I have heard the lug nut wrench is the same size but have not confirmed this.
Old July 11th, 2005, 03:46 PM
scoloco's Avatar
scoloco
'94 D90 ST
Standard alloy lug nuts (and I think the steel ones also) are 1 1/16". Oil drain plug is 1 1/8". Why rover has huge odd ball sizes is beyond me.
Old July 11th, 2005, 04:49 PM
gtg067i's Avatar
gtg067i
Christian Shea
That dang wrench wasn't easy to find. Neither Lowe's or Home Depot had one and it took me two other hardware stores to find it. Finally got it at Ace, which always has the stuff I need for the rover. Why I didn't go there first is beyond me. It's a big honkin wrench though.
Old July 11th, 2005, 04:56 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
Next time, try Sears Hardware. If the last person to change the oil was a shop it might be socked on there pretty tight, too. There is a learning curve with respect to getting the oil drain plug off without burning your hand on the exhaust or dropping the plug into the pan. The easiest thing for me has been to let it drain into a cat litter box bottom or plastic dish pan and then poor it into the empty new bottles for recycling. I tried those special "oil change" pans at the automotive sotres, but they get all gross and the oil seems to get all over the outside. You're also supposed to put the new oil in first before you remove the old oil filter. The large open collecting pan helps with this, too, although I've never been able to get the old filter off without spilling a little oil on the steering link in front of the diff. Good luck, and remember - a little oil on your skin never hurt anyone a little oil on your skin never hurt anyone a little oil on your skin never hurt anyone
oil change/oil cooler line change sirjond Defender Technical Discussions 12 January 25th, 2013 03:01 PM
Sick Of Messy Oil Change javelinadave Defender Technical Discussions 17 October 12th, 2004 09:28 PM
Oil Change Screw-up zed111 Defender Technical Discussions 9 July 19th, 2004 11:48 PM
