OIL change - Defender Source
Old May 27th, 2009, 10:44 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
OIL change
Hey,
Changing my oil this week and what is the proper oil to get. Should i use synthetic. and is it 5dash40 15dash40 etc... thanks
P.S. its on MY 95 d90 stock 88k mi
Old May 27th, 2009, 11:11 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
I have been using Shell Rotella 15-40 conventional oil after being recommended specifically for these motors by many people.
Old May 28th, 2009, 01:50 AM
Oil choices are diverse, but 0w40 mobil one or 5w40 synthetic is pretty well regarded (rotella synthetic 5w40 if you are of the opinion that diesel type oil is better). I alternate between the two depending on what I have on hand.
Old May 28th, 2009, 07:16 AM
Mobil1 10w40 hi milage and a NAPA 1542 oil filter. Take the drain plug out slowly. Refill the sump before you change your filter, fill the new filter. Should take about 8 quarts.
Old May 28th, 2009, 09:19 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Want to learn more than you ever wanted to know about what oil to use for your Rover? Go here: http://www.discoweb.org/forums/showthread.php?t=54420
and here (follow-up thread):
http://www.discoweb.org/forums/showthread.php?t=57504
There is another thread somewhere there but I did not find it.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old May 28th, 2009, 09:42 AM
GYM's Avatar
GYM
Gary
97 SW
Originally Posted by rover4x4
Refill the sump before you change your filter.
Why?
Old May 28th, 2009, 10:04 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Mobil 1 0w-40 if you want synthetic. Rotella 15w-40 for dino.
Old May 28th, 2009, 10:33 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
?? Isn't that a cartridge filter? Mine takes a spin-on. I use WIX 51515 (longer than OEM), about $4.50.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old May 28th, 2009, 10:52 AM
Originally Posted by GYM
Why?
So the pump does not lose prime. Also, I fill the oil filter with oil too.
I do it:
1. Drain oil (use oil filter box to block oil from hitting the exhaust) and refit drain plug.
2. Remove filter.
3. Put in 1 gallon of oil.
4. Fill new filter with oil and install.
5. Top up with total oil in at 6 quarts (pull dipstick out 2in or so to allow oil to enter engine properly).
6. Start engine.
7. Make sure oil light goes out.
8. Run for 1-2min.
9. Check oil level and top up additional as needed (usually takes between 6.5 and 7 quarts in total).
Old May 28th, 2009, 11:18 AM
GYM's Avatar
GYM
Gary
97 SW
I do it:
2. Remove filter.
6. Start engine.
8. Run for 1-2min.
This is exactly the way I do it as well.
I must have misinterpreted Philip's post. I read it to mean he fills the sump before removing the old filter. That is what did not make sense to me.
Old May 28th, 2009, 12:38 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
not to go too far off course but what would be better at keeping the engine running cooler? 0w-40? or 20w-50? I know the weights are more for season and weather conditions but would you think they would effect temperature too?
I would think the heavier weight would keep it cooler on short drives because it would take longer to warm up. though on longer highway driving the thinner weight would cool easier because it would not retain heat as long as it was circulated through the system.Any thoughts on this?
Old May 28th, 2009, 06:45 PM
I do fill the sump before I remove the old filter. My fuel milage decreased with the Rotella in my Classic.
Old May 28th, 2009, 08:16 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
I've heard this (and similar ways) are the best as opposed to just pulling the filter and plug and refilling. That being said I've always just pulled the plug and filter and made sure I've filled the filter all the way up (allowing oil to really soak/bubble in) and then fill 'er up. I've never lost prime before.... or at least I'm not aware that I have! How does one know if you've lost prime? (Short of the engine seizing up of course...)
Old May 28th, 2009, 08:18 PM
Oil light stays on=lost prime. Not much of an issue on 1997s due to the different pump design.
Ron
Old May 28th, 2009, 08:36 PM
JohnsD90's Avatar
JohnsD90
Rotella 5-40 it is, only because i have it on hand for my diesel jetta.
Old May 28th, 2009, 11:36 PM
specops1526's Avatar
specops1526
Beluga '97 90
x3 on the Mobil 1 0w-40, Just bought 7 quarts for an oil change tomorrow.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old August 19th, 2009, 03:56 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
How about high mileage mobil 1 10w30....ok to use?
Going to change the filter @500miles since first time w/syn
Old August 19th, 2009, 04:02 PM
btate
Bryan Tate
d90
any problems with Rotella 15-40 and using stock LR oil filter? (I still have a few filters left over)
Old August 19th, 2009, 07:07 PM
No. My machine shop guys says to using Valvoline Racing oil, its got the ZDDP.
Old August 19th, 2009, 07:13 PM
cellulararrest
Chris Snyder
It's about the rating, not what's actually in it. There are other ways to obtain the rating without ZDDP.
It's ACEA a3/b3 that you're after.
Oil Change gtg067i Defender Technical Discussions 31 July 13th, 2005 10:24 AM
Sick Of Messy Oil Change javelinadave Defender Technical Discussions 17 October 12th, 2004 09:28 PM
Oil Change Screw-up zed111 Defender Technical Discussions 9 July 19th, 2004 11:48 PM
