Ohhhhh S*&^%! - Defender Source
Old December 23rd, 2005, 04:31 PM
b.suder
Bridgette Suder
Red face Ohhhhh S*&^%!
My D90 keeps stalling out when I put it in first gear and slow down to stop. But it will run all day in nuetral. Any insight. Just please don't tell me i need to replace the entire clutch. Any help will be much appreciated.
Old December 23rd, 2005, 04:35 PM
well if you slow to a stop in any vehicle with a manual gearbox it will stall unless you push in the clutch pedal. We need more information miss
Old December 23rd, 2005, 07:08 PM
b.suder
Bridgette Suder
I put the car into first gear, then press the clutch and break.
Old December 23rd, 2005, 07:27 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
What color D do you have? Wondering if I've seen it around.
Jimmy Buffett
Old December 23rd, 2005, 07:56 PM
thats wierd, especially if i will idel in neutral
Old December 23rd, 2005, 08:37 PM
Hey Bridgette, from the sound of it the clutch is not disengaging all the way. I would check the clutch fluid first. If the clutch was going bad it would slip rather then stick. If the clutch fluid is low you may have a leaky master or slave cylinder, not the end of the world and not expensive, the master is a pain to replace but doable. If you do end up needing either it is a good idea to replace both as they don't cost much and the most time consuming part is bleeding the system.
Old December 23rd, 2005, 10:48 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Do you feel the truck jerking as if the clutch is still engaged when it stalls?
