Offset - Defender Source
Old March 1st, 2015, 05:42 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Offset
So I have been searching (for hours and have kept my title as specific as possible) but now reaching out for opinions.
Ive been looking at an alloy rim that is 16 x 8J with 5mm +ve offset.
Given that standard alloys are abour 33 mm offset, calculators show that with this new wheel:
Inner clearance would be 15mm more
Outer would extend an extra 41mm
Is this extension considered excessive, given that some are running spacers?
And, do you think I could run 265 x 75's with standard ride height on a 90?
I actually like the standard ride height and springs
Regards.
Old March 1st, 2015, 06:03 PM
I run stock Freestyles with 50mm spacers and 32.00 x 11.50-16 tires (Super Swamper TSL-SX).
No rubbing at full lock with the spacers. Lots of rub without the spacers. No other problems that I can observe after some wheeling (rock crawling).
I don't anticipate any issues with your setup as your describe.
fs
Rovertym Rear Links, Offset Radius Arms Wolf Fabrication Wanted 31 March 28th, 2010 08:57 PM
110 wheel offset cdb Defender Technical Discussions 1 November 2nd, 2008 10:09 AM
Euro Offset Steel Wheels GYM Defender Technical Discussions 4 October 24th, 2007 08:02 PM
Stock alloy offset Trigger Defender Technical Discussions 4 April 25th, 2006 10:08 AM
Near New Offset Rockware tie-rod.... dmarchand For Sale - Parts 2 June 1st, 2004 02:32 PM
