Offroad lights? - Defender Source
Old December 5th, 2010, 09:09 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
Offroad lights?
What should I go with the Hella 4000 or the lightforce 170's?
Old December 5th, 2010, 10:03 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
You can get Hella 4000 euro beam for around 90$ on amazon (each).
They work great, just be sure to install them with proper wire and one relay for each light.
- Charles Eames
Old December 5th, 2010, 10:13 PM
I am very pleased with my 4000's.
Old December 5th, 2010, 10:47 PM
cdb
Clark Bowen
I rolled my D90 2 1/2 times down rock with Light Force 140s on the to of my brush bar and they don't show any damage and still are working fine 4 years later.
2011 RR HSE -
2001 GMC 2500 4wd
Old December 6th, 2010, 09:41 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
One relay per pair is all that is needed.
Dave
Old December 6th, 2010, 10:54 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Dave
In my experience when you put that load on a single relay ( the euro beam version is 100 watt so we're talking 16 amp), you get a lot of sparkles inside the relay that will create deposits on contacts (premature failure). I don't know in the US but here a 12 volt Bosch relay is less than 10 bucks so i don't see the point.
- Charles Eames
Old December 8th, 2010, 08:53 AM
dchapman
Daniel Chapman
1999 D1
Never had these issues. And I think my Bosch relays were $1.77 on ebay.
Dana, go with the Hellas.
Old December 8th, 2010, 09:46 AM
DMSLongLake
Dave Sherwood
1994 D90 ST
Sparkles?
If you do the math, one relay is more than enough for a pair of 100w Hellas...
The harness for the 4000s from Hella run one relay per pair as well...
Old December 8th, 2010, 10:01 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Originally Posted by DMSLongLake View Post
Sparkles?
Just make sure to get a good brand relay. Using cheap ones, I tend to blow out a 35amp relay at least once a year driving my cooling fans...... which are only pulling 20 amps.
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 8th, 2010, 09:39 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
I have the 4000 and like them. I used the wire harness from hella, not sure if it has two relays but I never had a problem.I did have to cut holes in my grill for the depth...I used the light bar for the front bumper. Not sure anyone else had to do this but I was like f' it I can always get a new grill if I want to loss the lights.. Don't really like the switch though, anyone ever change that?
ht, lights
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
Hinged fog lights. rustydefender Defender Technical Discussions 2 February 28th, 2005 09:33 PM
flickering lights nykx Defender Technical Discussions 1 November 12th, 2004 06:10 PM
Back lights all out vnrover Defender Technical Discussions 7 June 21st, 2004 12:04 AM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
