off-set clutch in 300tdi match up to r380 - Defender Source
Old April 6th, 2012, 04:58 PM
kim's Avatar
kim
kim knotts
1994 d-90 300 tdi #199
looking for some information/help doing a conversion, 94 gas to 300 TDI bought from a guy named Duncan.
Part of the pkg. is an "off set clutch assembly" that is supposed to eliminate the need of replacing the transmission shaft with a longer one. R380 for gas.
The problem is that what I have received clearly does not work, does anybody have any experience with this kind of assembly? Is even such a kit? Duncan is indicating that the shop simple does not know how to do the work.
kim
Old April 7th, 2012, 01:42 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Not heard of such a thing. I think the bolt pattern on the two engines is different and you need the correct bellhousing for the engine.
Mike Hammond
Old April 7th, 2012, 04:30 PM
kim's Avatar
kim
kim knotts
Mike,
right on the bolt pattern, but as for the clutch apparently the clutch plate assembly is offset to accept the shorter us shaft on the r380 tran.[gas] as compared to the diesel.
Old April 8th, 2012, 01:28 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
This sounds similar to what m&d engineering does. They supply adapters for your V8 r380 to mat up to a 300tdi. Do you have an adapter plate or is it a clutch assembly that extends out?
Can you post up a photo of what you got?
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old April 8th, 2012, 04:18 AM
mikeslandrover
Mike Hammond
I dont quite follow. Does that mean the input shaft is no longer supported by the pilot bushing?
-Jeff
Don't think that would last too well
------ Follow up post added April 8th, 2012 09:18 AM ------
That would be good.
Mike Hammond
Old April 8th, 2012, 10:03 AM
kim's Avatar
kim
kim knotts
attached are two pictures of what I have
kim
Old April 8th, 2012, 10:27 AM
My understanding is that the real difference is with the pilot bearing size and location and that needs to be addressed.
Old April 8th, 2012, 10:32 AM
kim's Avatar
kim
kim knotts
Do not know, was told by the guy that sold me the engine, bell-housing and off-set clutch plate that this is all that is needed.
------ Follow up post added April 8th, 2012 10:36 AM ------
John,
I guess I should add that the shop that has my D-90 is saying that this will not work(even if it snows in hell) and that I need a longer shaft from the transmission(for a diesel)
Old April 8th, 2012, 11:13 AM
Yes, I would assume you would need a custom flywheel that is spaced over and contain the pilot bearing.
The problem is that some "hacks" have done it before. The spline engagement is wrong and there is no pilot bearing support. It "works" but the clutch and gearbox are subjected to things they should not see.
Old April 8th, 2012, 02:45 PM
mikeslandrover
Mike Hammond
Yep, the bolt pattern for the engine to the transmission won't match, you'd find it easier to get a diesel R380 transmission.
http://www.ebay.co.uk/itm/R380-Gearb...#ht_600wt_1091
As you can see in the photos for this item, the bolt pattern isn't anywhere near the same.
Mike Hammond
Old April 8th, 2012, 03:12 PM
kim's Avatar
kim
kim knotts
Thanks Mike, I will give it a look.
kim
300tdi, clutch, r380, tdi
WANTED: Clutch for '94 D90 with R380 jijalicious Wanted 4 December 21st, 2011 10:50 PM
300Tdi wings/ radiator finisher (defender) Lyman Wanted 2 March 8th, 2006 05:51 AM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
clutch jperakis Defender Technical Discussions 2 March 19th, 2004 06:23 PM
