Of Nuts and Bolts and Defender Doors - Defender Source
Old August 17th, 2016, 02:44 PM
RBBailey
RBBailey
1965 IIa
Trying to get my doors back on, but the captive nuts I bought don't actually fit in through the square access hole, they are too wide.
So I'm carefully trying to not drop them in by turning them this way and that to get another angle.
Actually, now I'm eating lunch, but after lunch I will do this. So am I at it in the right way, or did I end up with the wrong nuts?
Project:
1965 IIa SWB
Old August 17th, 2016, 02:50 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Nope, you're doing it right. I have seen that the reproduction units are a little easier to fit if you put them into a vise and pinch the cage around the captive nut a little tighter.
Use a thin flat-head screwdriver to help the install -- insert it into the cage nut from the larger rectangular opening in the firewall (the middle of the three holes) and use it to leverage the assembly into place.
There are two different thread pitches out there, so make sure they match your door bolts before going too far.
-Ash
Geared Restoration Co.
352-572-3236
Old August 17th, 2016, 02:57 PM
Naplm00
M
I dropped mine in the bulkhead once as well. A $2 telescoping magnetic pickup saved me a lifetime of rattling
Old August 17th, 2016, 03:01 PM
One of my least favorite defender tasks.
Old August 17th, 2016, 03:19 PM
RBBailey
RBBailey
1965 IIa
I'm also trying to put the headliner in today......
Thanks for info, Ash.
Project:
1965 IIa SWB
bolts, defender, door
Getting down to the nuts and bolts - c hoop & cantrails geoellis Defender Technical Discussions 4 August 2nd, 2011 04:29 PM
Nuts and Bolts Kit The Dro Series Technical Discussions 8 July 5th, 2011 12:14 PM
ROAV Summer Nuts and Bolts Rally July 31-August 2 ukoffroad Trips, Trails and Events 16 August 4th, 2009 11:44 AM
What thread pitch are the big bolts on the tire carrier and the lug nuts? evilfij Defender Technical Discussions 5 April 20th, 2009 01:38 PM
Nuts and bolts ... Retrofit Defender Technical Discussions 8 August 11th, 2007 04:39 AM
