OEM tyre pressure on NAS D90s - Defender Source
Old May 21st, 2005, 04:41 AM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
Hey guys,
I've installed BFG AT/ko on my truck, the same tyre/size that came with the NAS 90s...
I'm wondering what was the original pressure that was recommended for street for these tyres by Land Rover? I've been playing around for the past 2 weeks and think that I may a wee bit off (did the chalk, heat & weight tests/routes)...
Thanks...
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
Old May 21st, 2005, 07:22 AM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
Normal
1.9 bar front (28 psi)
2.4 bar rear (35 psi)
Old May 21st, 2005, 04:28 PM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
Great - Thanks...
Given its a diesel, I'll up the front a bit...
FWIW, I was at 32psi front, 34 rear, which is close...
'04 Disco II stock
Old May 21st, 2005, 04:49 PM
I run 35psi all the way around with my GY 285/75/16's.
90, d90, nas, oem
NAS 110 A/C High Pressure Valve Mikenbama Wanted 6 September 1st, 2009 02:30 AM
FS NAS 110 Stuff and OEM Speaker Grills surf110 For Sale - Parts 7 June 16th, 2009 12:32 AM
BF Goodrich Tyre Pressure Recommendations Manimal Defender Technical Discussions 5 November 5th, 2008 11:43 AM
'95 NAS D90's vehicle dimensions NJ-D90 Defender Technical Discussions 1 June 2nd, 2004 08:01 AM
