odometer question - Defender Source
Old March 24th, 2012, 07:06 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
odometer question
The odometer just stopped a month ago, so MPH and the actual milage counter stopped but all other gages work. Question, is there a cable that can be simply replaced or does the whole instrument panel have to be replaced. this is for a 1995 D90.
Thank you.
Old March 24th, 2012, 08:12 PM
If it was working nice and smoothly before it stopped then I'd guess it's possible the speedo cable just came loose ... there are 4 screws that hold the instrument panel ... this comes forward gently and the cable can be seen at the back of the odometer ... you could try pushing it back on if it's loose. Dont pull it off without being very careful ... they can be pretty fragile.
Looks like you only live a few blocks away ...
Odometer reads 76% actual miles stevewhitaker Defender Technical Discussions 4 January 21st, 2006 06:07 PM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
Can anybody do a Vin Check for me? Quimbola Misc. Chit-Chat 7 February 18th, 2004 06:24 PM
