Odd transfer case failure - any input? - Defender Source
Old April 27th, 2015, 09:30 PM
This was written up in the "Toughest Trail Fix" thread, but so far this failure has everyone - including myself - stumped.
Cliffs notes on the situation leading up to it:
- was off road, going over a small/medium obstacle (nothing insane by any means...call it a "Galpin Green" : ).
- difflock/CDL was on, as well as my rear locker (I believe I had the rear on, but CDL for sure).
- I was trying to get up-and-over, just feathering the gas...was not hammering it by any means.
- there was no "pop" or anything, it just suddenly stopped going...we thought the tcase may have popped into neutral or had a linkage issue.
- tugged it back to camp, did diagnostics, and initially thought the crosspins had failed.
- pulled & replaced the tcase in situ at camp (after a trip to get a suitable replacement).
Anyhow, I finally got around to pulling the tcase apart on the bench this weekend. I was fully expecting to find the crosspins snapped/etc, but when I pulled it apart I was surprised to find the nose of the casting/housing for the center diff itself had actually sheared off as seen in the below photos.
Any ideas WHY this would have happened? I've discussed this with some of the resident "experts" (as well as some weathered Rover techs), and it seems to have everyone scratching their heads. Best theory to date seems to be a fault or bad casting in the diff housing...but any other input?
ID:	119351   Click image for larger version
ID:	119353   Click image for larger version
Old April 27th, 2015, 10:00 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Where did you get that box? Is it a suffix A serial number? That is a very early center differential. What is the serial number?
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old April 27th, 2015, 10:05 PM
Rob, this is the tcase I was telling you about when we chatted on the phone last week (and the issues extended to the output shaft on the trans with the spline wear). At that point I had not dug into it, and was still assuming the crosspins had failed.
Appears to be a suffix-E, Serial# is 28D280383E.
It was actually a replacement installed by a prior-owner, and *supposedly* he got it from AB as a rebuild...based on my calculations it only has about 20K miles on it between when the PO put it in and the mileage I've put on it since then.
Old April 27th, 2015, 10:27 PM
Probably just a bad casting. I had an intermediate gear pop off one day on the street. Sometimes these things have flaws.
Old April 29th, 2015, 02:28 AM
The unfortunate downside of rebuilds is that they reuse virtually all the components minus worn or broken items.
sorry jason...on the other hand...at least it wasn't so catastrophic that the rest of the tcase suffered permanent damage!
Old May 1st, 2015, 03:40 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Hi Jason,
took two pictures of two different diffhousings today.
Left is the newer one:
Have a look at the different type of radius between the shaft and shoulder:
My intension is that the broken area is old (it's covered with old grey brown oil). No wonder there was no kracking noise when it happens. The shaft had been broken 90% at that time.
I would call this a long term torsion break (Torsionsdauerbruch in German). Typical for that is the angle of the cone: it's almost 45. The source was the very small radius.
I would like to get a BKB for this info!
picr.de seems to be out of order for a while.
Try again later.
And please hold the line.
Old May 1st, 2015, 04:39 PM
makes sense, arlo. There's significantly more material on the newer style than the older style.
Old May 1st, 2015, 05:18 PM
Have we found a name for your truck?
Originally Posted by pendy
I'm here for the D's
Old May 1st, 2015, 05:30 PM
You have to have at least 3 engine fires before you can earn that title.
Old May 1st, 2015, 07:12 PM
Hi Jason,
Try again later.
Arlo:
Very interesting...Roadside Rob seemed to have alluded to that (my internals were "older" than they should have been). The irony of all of this, is that my tcase has a 28D serial# (suffix E) and would *lead* one to believe it was/should be newer components. Additionally, the prior owner got the tcase as a rebuild unit from AB (I believe) <20K miles ago. Seems that *someone* was touting a new tcase/rebuild...but with ANCIENT parts.
Not to fear, as I now have a suffix-G case in my possession that will go in my truck in the interim, and my psuedo-plan is to rebuild my old case with 1.003 ratio gears when I get the chance.
ID:	119670   Click image for larger version
transfer case
Nylock nut size, rear flange of transfer case - also identify T-case ratio hillstrubl Defender Technical Discussions 3 July 11th, 2012 02:42 PM
Tips on Swapping out the T-Case input Gear? LRNAD90 Defender Technical Discussions 2 April 23rd, 2009 05:14 PM
Transfer box input bearing preload reb78 Defender Technical Discussions 10 October 29th, 2008 05:04 PM
transfer case . . . transfer Abrooks Defender Technical Discussions 38 October 20th, 2008 09:04 AM
T-case input shaft Bearing #s Mike Hippert Defender Technical Discussions 10 June 8th, 2005 06:52 PM
