Odd Temperature Rise 200tdi - Defender Source
Old July 9th, 2010, 09:40 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I drove 25 miles at about 630pm tonight and the engine temp gauge never went above 190 Degrees, It was about 90 degrees outside at the time. Parked the truck for 2 hours and when I drove home at 9pm with the outside temp at least 10 degrees cooler, the engine temp went up to about 205-210.
Anyone know why this would happen?
The truck has run warmer at night before, but I thought it was just a freak thing.
Old July 9th, 2010, 10:23 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Could be a lazy thermostat. May want to change or test it before it really lets you down.
Or by one of my clutchless fans and it will be practically aircooled with the propwash rushing by it. lol
legend in my own mind
Old July 9th, 2010, 11:06 PM
Yeah mine runs hot at night too. Odd isn't it? Well when I drive during the day with the lights on it gets hot also. Turn the lights off and it gets cool again. Hmmmm...voltage drop in the system due to the undersized headlight circuit? Bit of Ohm's Law tit-for-tat, or what have you, and your gauge reads high or low, depending. Others report the same problem. Towing uphill it actually does get hot. But not terribly so, 205F maybe -higher at night- but she held.
Old July 10th, 2010, 07:02 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Pendy, isnt 205 a normal temp for a Tdi? If your gauge reads different with your headlights on, That is prob a ground problem. I had this prob once. Run a dirrect ground to your temp gauge.
Legend in My Own Mind.
Old July 10th, 2010, 08:28 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Awesome plug! Wouldn't that super fan keep it too cool, or is that impossible?
I'll check if it's headlight related, I hadn't thought of that.
Old July 11th, 2010, 08:59 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Good call DB and Randy, it was headlight related. As soon as I turned them on today the gauge went up 10 degrees. It was odd that it wasn't always 10, I did it a few times and it seem to change between 10-15?
where should I run the new ground from?
Old July 12th, 2010, 06:19 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Mine runs normally at 200-205, and hit close to 215 these past few days with the outside temp hit 100.
Semper Fi!
Old July 5th, 2011, 06:34 PM
piekas's Avatar
piekas
Pierre Jourda
1987 Defender 110
Bringing an older thread back to life. Just replaced my old thermostat (with which temperature guage used to be right in the middle). New thermostat (also an 88C) causes guage to be in 3/4 position, at edge of white. We all know that the stock guages are approximations. In my case, I don't know if the old thermostat was letting too much through or the new one not enough, or whether the new is actually just fine. I've searched high and low, but can't find what the target operating temperature range should be for the 200TDI. Anyone know?
-P
Old July 5th, 2011, 09:18 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
I have similar experience to many 200 tdi owners when the outside temp goes into the mid - upper 80's... my guage registers slightly below the warning orange range. In the winter, the guage hardly registers at all. In normal to moderate temps, it registers in the center of the temp guage. I am emailing pendy and inquiring about the clutchless fan. Although I have heard running too cool is not good (my truck runs very cool in the winter), I am much more concerned about overheating. After all, I guess I can control too cool engine temp with a grill muff in the winter.
200tdi, tdi
Temperature Gague false reading trick? arbik Defender Technical Discussions 67 April 30th, 2017 09:45 PM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
Temperature Gauge doesn't work...?? norros Defender Technical Discussions 4 May 19th, 2004 04:11 PM
