Odd sized hex bolts on Defender - Imperial ?? - Defender Source
Old January 24th, 2016, 09:12 PM
agentmulder
Agent Mulder
2008 110 PUMA
Hello,
Discussing the external rear view mirror arms (with the spring loaded rotational mount at the door hinge end and the ball at the mirror end).
I need to remove mine (removing to repaint after corrosion removal) but the hex socket (underneath the plastic insert) has a measurement of 7.7mm between flats
Looking at an fractional imperial to metric chart I see that this measurement sits between:
5/16 @ 7.94mm (too large) and 19/64 @ 7.54mm
I don't have a 7mm hex key, but suggest it would be too small anyway, so is 19/64 a common hex key size ? And why would LR do that ?
Removing the whole lot (door hinge etc.) and masking the joint for painting it is an option, but I'd rather just go direct if possible.
What am I missing?
Old February 5th, 2016, 01:08 AM
Dogpilot's Avatar
Dogpilot
James Wallace
Defender 90 1997 NAS ST
I don't think that is a hex screw. The one on mine is a crimped piece that does not unscrew, The crimp looks like a hex screw, but it isn't.
Old July 1st, 2016, 01:00 AM
KJKinCO
CC
1995 NAS Defender 90
I have the same situation Agent Mulder - did you figure out how to best remove these? Thanks.
bolts, defender
Not mine used Imperial II-class Star Destroyer roverman2010 The Flea Market 11 April 23rd, 2015 07:02 PM
Hex Nut and Bolt Protection Cap Rugbier Wanted 6 March 13th, 2010 11:28 PM
Imperial Fan Clutch replacement souza Defender Technical Discussions 11 August 19th, 2008 11:36 PM
Truck covers - fitting over a full rack - D sized paulb Misc. Chit-Chat 0 October 10th, 2007 08:58 AM
sparkplugs sized for 4.6 or 3.9 Davis Defender Technical Discussions 1 April 11th, 2005 09:28 PM
