Odd Question. - Defender Source
Old July 4th, 2008, 04:07 PM
bjp
Brent
1995 D90
Odd Question.
I recently replaced the rear load mat. I sold the bench seat and replaced the bolts on the load floor. My question is is there a bolt out there that has a flat head that will fit flush to the floor. I do not want the mat to tear where the top of the bolts are. Installing jump seats and passengers feet will be right on top of them. Do not want to have the bolts exposed on top of the mat either. Ace Hard. had stove top screws which i thought would work but the tapper on top of the screw still made the screw sit up as high as a regular bolt. Other thought was to get a short bolt and try to go though the under side but I do not think I have enough room. Need to check. Any other ideas. I know its a little anal.
Old July 4th, 2008, 11:01 PM
themaxx's Avatar
themaxx
Ade
94 ST
How about using a grommet like rubber stop without a hole.
Old July 4th, 2008, 11:37 PM
Why again do you want a bolt in there? Pull it out and pack the holes with antiseize of grease and put some tape on top of them
Old July 5th, 2008, 07:31 AM
Land rover used special dots of black masking tape from the factory. I see no reason not to upgrade and use nicely cut dots of black duct tape.
Slider Question kellymoe Defender Technical Discussions 13 January 24th, 2006 04:52 AM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
Odd intake compatibility question for Rover Tech types Hans Defender Technical Discussions 3 December 13th, 2004 07:39 PM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
