Odd part number request ... - Defender Source
Old March 28th, 2009, 10:07 AM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
I can usually locate all my part numbers but this one leaves me with nothing.
I am looking for the part number for the two bearing (top and bottom) in the steering column of a Defender. One is a roller pin bearing and the other is a ball bearing.
If anyone can help I would be very happy.
Thanks everyone.
Pat
Kirk Lazarus, Tropic Thunder
Old March 28th, 2009, 12:55 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
They're not available as separate items, BUT, you can remove them easily (well, after you've had a fight to get the whole column out)
So you can try and match them up with some replacements.
There was a thread on LR4x4 a while back (just tried searching for it but to no avail) where i think, at least one of the bearings was identified with a substitute.
Old March 30th, 2009, 10:43 AM
Retrofit's Avatar
Retrofit
Pat
Thanks Jim,
I guess I will have to figure out something on my own on this one as I cannot find anything relating to these parts.
I will definitely post the pat numbers and what not once I have this puzzle solved.
Pat
Old March 31st, 2009, 02:31 PM
Retrofit's Avatar
Retrofit
Pat
Would anyone have some of those used on hand for sale ???
Pat
Old April 3rd, 2009, 04:53 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Pat
It's bluddy typical... i had a mega garage clear out the week before last and threw a complete steering column out! (with bearings in....)
Old April 3rd, 2009, 12:01 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Usually on the edge of the bearing outer ring, is a part number (stamped or etched into the metal). A good bearing shop can locate a replacement from that number. The race (inner part) will usually have a number too, as for any given bearing the shaft going through the ID can vary, yet use the same bearing.
Dennis
Old July 19th, 2009, 11:37 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Has anyone had luck finding these? One of mine broke (who puts thin races inside a rubber collar anyway...) and the other is crunchy.
Old July 19th, 2009, 07:00 PM
jetmech's Avatar
jetmech
Dave McHenry
1984 Landrover 90 CSW
try these part numbers from timken
Upper:
5BC NP224896
Lower:
11590-11520
Inch Series -- Model 11590/11520SPECIFICATIONSView Entire DatasheetTypeSingle Row Tapered ApplicationAgriculture; Automotive; Pump; Spindle / Super Precision; Construction Equipment, Mining Equipment Design UnitsInch Bore0.6250 inchOutside Diameter1.5745 inchNotesTapered roller bearings, allows for both radial and thrust load
Old July 20th, 2009, 03:15 PM
ajh
Andrew J. Hutton
GBS Bearing in Ottawa had:
5BC 10.09CAD
11590 25.75CAD
11420 10.52CAD
but they tell me that NP224896 is only available through Timken dealers located in .uk or .fr and suggested Eriks Group as a place to source them. If I am going to bring in some I might as well bring in a bunch if anyone else needs them.
part
Part number for front marker lenses? Hans Misc. Chit-Chat 4 December 3rd, 2005 11:00 PM
Part number for 300tdi D90 steering wheel? dmarchand Misc. Chit-Chat 12 June 22nd, 2004 10:28 AM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
Part number for genuine roof rack? wicks Defender Technical Discussions 13 March 3rd, 2004 06:34 PM
Part Number Cross Reference Database mlepisto Misc. Chit-Chat 8 December 19th, 2003 12:52 AM
» Defender Registry
#401/500
ixselr8
cjbenway
Add your Defender
