Odd fuel tank leak - Defender Source
Old June 27th, 2013, 08:19 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Odd fuel tank leak
My under seat tank has a sporadic leak. It started to leak a bit as we were taking the truck apart. I figured it was the drain and put a new washer on there before I put fuel in the tank. I put in 3+ gallons and let it sit for 2 days, no leak. Yesterday I put hoses on the fuel line and return but didn't put clamps on them. This AM there as a puddle of diesel, the sender and the return were dry but there was a slow drip at the low point of the tank. (Away from the drain plug)
Any ideas?
Old June 27th, 2013, 09:12 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
The guy who did that really really clean and sweet resto of a lightweight has photos showing where there are spot wields on the bottom of the tank and that can corrode and where most of the leaks come from and not around the drain plug itself. Turns out the tank bottom is layers of steel welded together. He has a build thread on the RN forum in the series section. He also posted his lightweight in the registry on here some months ago.
fuel
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
Leaky Fuel Tank cbass Defender Technical Discussions 12 June 2nd, 2005 04:50 PM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
