odd electrical issue - anyone seen this one? - Defender Source
Old December 24th, 2013, 11:21 AM
akrockhound's Avatar
akrockhound
Jack
1988 RHD 110
My '88 ROW 110 has done this twice. While driving, the radio and heater fan turn off and the ignition switch chimes (like it does after you turn engine off). The engine keeps running and all other electrical circuits (like the lights) keep working fine.
What it looks like is that the entire circuit that is only on when the ignition is on - suddenly turns off. If I shut down/restart the vehicle it all comes back on.
Wiggling the ignition key does not help. I realize it could be a loose wire in the ignition, or a bad ground almost anywhere, but wondered if this circuit is on a relay and maybe the relay is failing. Anyone know if/where the relay is? My hunch is that its a bad connection between the ignition switch and the relay or the relay is failing.
Is there a way to identify the wiring for this "ignition on only" circuit so I can follow it around to look for loose connections or ground?
I appreciate any ideas.
'88 ROW 110 5-door SOLD
'01 Disco II
'95 RRC LWB
Old December 24th, 2013, 11:48 AM
start with the ignition switch ...
Old December 24th, 2013, 05:31 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
It is easy to pull the plastic off the steering column and check the wiring on the back of the switch. If it works again you may have a bare wire problem but more than likely it is the switch as mentioned above. Off the back of the switch you will have a switched circuit that goes to the fuse box. Some of the newer trucks will have a maxi fuse box on the firewall. If you do a search you can find a wiring diagram and start troubleshooting it. However those switches do go bad.
electrical
Need more help on electrical issue akrockhound Defender Technical Discussions 8 October 12th, 2013 01:21 PM
Electrical issue? Turn Signal / Brake pedal Flagg Defender Technical Discussions 5 November 9th, 2012 02:08 PM
Electrical Issue lordhelemt Defender Technical Discussions 1 June 26th, 2011 09:15 PM
110 electrical issue bcourtney Defender Technical Discussions 4 August 6th, 2008 06:40 AM
Need help diagnosing electrical issue cgalpin Defender Technical Discussions 22 January 25th, 2007 08:53 PM
