Odd connection at the aut gearbox - Defender Source
Old May 4th, 2011, 02:44 AM
jeangtd
Gabriel
nas 97 soft top
so im trying to get my electrical system checked out because the previous owner had an animal for an electrical technitian, and have found some horrors. like this one. the pic pretty much explains itself. but what isnt shown in the oic is that the black cable runs al the way to the back of the truck. what is this connector? and why did they do this mod?
Old May 4th, 2011, 09:53 AM
jeangtd
Gabriel
nas 97 soft top
nobody? i searched the rave for the connector with no luck
Old May 4th, 2011, 10:08 AM
Grover's Avatar
Grover
In your earlier post you stated the CATs were removed, with that said, it looks like the O2 sensors/wiring were bypassed with a jumper.
Oh yah, welcome to the forum...
Old May 4th, 2011, 10:09 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Hard to tell, but my rough guess is that they tied into the reverse light signal (in that round black plug) and installed some sort of rear extra reverse light????
Doing it that way instead of using a relay like they should have.
Email:
Old May 4th, 2011, 10:12 AM
jeangtd
Gabriel
nas 97 soft top
so its not an oem connector?
Old May 4th, 2011, 10:13 AM
ECR's Avatar
ECR
The round black plug is factory. That is the gearbox start inhibit/ reverse light switch connector.
Email:
Old May 4th, 2011, 10:16 AM
jeangtd
Gabriel
nas 97 soft top
but my revrse light is working just fine. what else does it do?
Old May 4th, 2011, 10:52 AM
PaulMc's Avatar
PaulMc
Paul McConnell
1989 110 2.5 Turbo-Diesel
Connector #1 in your picture, looks like C684
Name:	C684 - NAS90.jpg
Paul.
1989 Arles Blue 2.5TD 110 Hardtop
1999 Epsom Green Discovery II 4.0 V8i 'XS'
Old May 4th, 2011, 11:43 AM
ECR's Avatar
ECR
You are thinking about it wrong. You are thinking it must do something. It isn't a factory thing, so you need to trace it. It could have been a wire for a rear work light that used to be there. It may go nowhere.
Trace that large orange wire and see where it goes, because it isn't factory. It may go nowhere. If it does go somewhere, you'll only find out by tracing it.
------ Follow up post added May 4th, 2011 11:47 AM ------
"extra" reverse light.
Your factory reverse light will work because it is factory. You were asking what the large added on wire did. So an "extra" reverse light (as in having 2) was my guess.
The switch is the start inhibit / reverse switch. It is part of the system that runs the reverse light and makes it so you can't start the car in gear, and it is also tied into the transfer case interlock that makes it so you can't shift the transfer case unless you are in P or N.
What that large orange wire is is anyones guess.
Email:
Old May 4th, 2011, 02:12 PM
jeangtd
Gabriel
nas 97 soft top
so if i leave it alone, nothing should happen right?
Old May 4th, 2011, 02:30 PM
ECR's Avatar
ECR
Impossible to say.
I wouldn't.
If some hack scabbed that into my truck I'd sure want it out, or want to know what it does at least. That is a large wire that can handle a lot of amps. If it shorts out it'll take out the harness or something and if the wiring is botched like you say, you know it isn't fused anywhere.
Email:
I've broken my gearbox!!! mikeslandrover Defender Technical Discussions 6 May 29th, 2006 05:04 PM
Think there is a connection? JohnK Misc. Chit-Chat 2 April 6th, 2005 01:16 AM
'97 D90 external gearbox cooler pipes. kiphartzell Defender Technical Discussions 0 March 29th, 2005 11:51 AM
140amp alterantor from rover connection - ROCKS! solihul Defender Technical Discussions 5 March 19th, 2005 02:42 PM
Server Connection Problems chrisvonc Community News & Announcements 1 July 25th, 2004 10:22 PM
