odd clutch problem - Defender Source
Old November 29th, 2009, 05:08 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
odd clutch problem
When I started the truck this morning it seemed as if something had changed with my clutch.
My clutch had previously engaged a bit on the high side, and was pretty tight at the top.
Today the clutch seems to engage much lower and is a bit mushy at the very top.
It still works fine, its just an odd difference.
Springs are all still there.
The fluid in the master is fine
no leaks
It was a bit cold last night, but nothing crazy(first cold night with the "new" engine and clutch setup)
Any ideas?
Many Thanks
Old November 29th, 2009, 07:20 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Strange. No leaks?
Maybe you should bleed it, there cold be some air?
clutch
clutch problem diagnosis help... bharris Defender Technical Discussions 18 November 14th, 2011 04:42 PM
Clutch problem Capt Milks Defender Technical Discussions 0 February 11th, 2007 09:49 AM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
