ODBII Code P1138 - Defender Source
Old November 8th, 2007, 09:09 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
ODBII Code P1138
I keep getting this code, I have put new O2 sensors in a couple of months ago. I have cleared it a number of times. How can I fix it for good? My cats have 55,000 miles on them.
Old November 8th, 2007, 10:20 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Shooting in the dark:
http://discoweb.org/forums/showthrea...ighlight=P1138
Somehow, might contain some useful info on the GEMS system:
http://www.gomog.com/allmorgan/GEMS/GEMSbyPoole.pdf
MonLand
1995 D90 NAS
1996 Discovery NAS
Old November 8th, 2007, 10:28 PM
Hey Loic, do you have an OBDII reader? New nova guy (Gregg) needs to check his codes on his '97 with starting issue.
Old November 9th, 2007, 12:50 AM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
dana, are you getting a check engine light with the p1138 or, are you finding the code on the code reader only, without the check engine light....upstream bank A o2 sensor fault will light the lamp but not the down stream its a sniffer only. iirc bank A is drivers, still have your old o2 sensors?? swap that one out and check...also in the annals of my d2's history, the po reported getting the same code, turned out to be bent pin all the way up at the ecm according to the techs notes....report back when you can
jeff
Old November 12th, 2007, 04:40 PM
MonLand
Loic Fabro
Kinda..... I have a cable and the laptop that I used to plug it into, but..... I lost the power supply for the laptop...... But last I used it the setup was working fine!
Now, Advanced Auto Parts will read the codes for you and reset the light for free. Maybe that's easier that looking for a power supply....
MonLand
1995 D90 NAS
1996 Discovery NAS
yet another radio code question GliderKing Defender Technical Discussions 3 June 4th, 2005 05:06 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
Fault Code Help howellm70 Defender Technical Discussions 1 January 30th, 2005 05:43 PM
D90 Stock Cassette Deck Security Code? Erik Defender Technical Discussions 4 December 9th, 2004 06:56 AM
