Occasional Hissing from under dash..?? - Defender Source
Old April 18th, 2004, 11:31 PM
P1CR
Mazen Fawaz
97' D90 SW, Arles Blue
any thoughts??
it happens every few minutes or so...
Maz
97' D-90 SW
Arles Blue
Old April 19th, 2004, 01:03 AM
WCURoverD90's Avatar
WCURoverD90
Jason Habbal
1997 Defender 90 #1104
hmmm on a station wagon....Do the station wagons have the vents in the dash that you can open and close for more air circulation...if so you might want to check the alignment on them...If not you may have a seal or something missing...I am not real familiar with the SW's but i know on my ST that I had some water leakage and a hissing and the vents were out of alignment...after i tightend them up and aligned them i have had no further problems....
Jason Habbal
"tell them to phucough"
Land Rover-The Best 4x4xFar
Old April 19th, 2004, 09:57 AM
n-m
Old April 19th, 2004, 09:58 AM
P1CR
Mazen Fawaz
Definately not the vents...
n-m??
Maz
97' D-90 SW
Arles Blue
Old April 19th, 2004, 10:05 AM
WCURoverD90
Jason Habbal
I didn't know if the SW's even had the vents in them......I just know i had the same thing of my ST and when i adjusted the vents it went away
Jason Habbal
Old April 19th, 2004, 10:07 AM
P1CR
Mazen Fawaz
I wish it was the vents. it's a very strange intermittent noise.
I've had some bad wind noise from them on occasion...
Maz
97' D-90 SW
Arles Blue
Old April 19th, 2004, 10:09 AM
When do you notice it? what conditions?
Old April 19th, 2004, 10:11 AM
P1CR
Mazen Fawaz
when I'm driving.
ha! but really, it seems to have started in the past few days, and just comes and goes every several minutes irrespective of speed, weather, etc.
Maz
97' D-90 SW
Arles Blue
Old April 19th, 2004, 10:12 AM
N-m = no message, SW have vents though. have you popped the hood to see if you can tell what its coming from. Could be a bad vacuum line.
Old April 19th, 2004, 10:13 AM
P1CR
Mazen Fawaz
Haven't been under the hood yet.
I'll check tonight.
I'm pretty sure it comes from the lower passsenger side dash area.
Maz
97' D-90 SW
Arles Blue
Old April 19th, 2004, 10:14 AM
P1CR
Mazen Fawaz
Thanks for all the help everyone...much appreciated as usual
Maz
97' D-90 SW
Arles Blue
Old April 19th, 2004, 05:37 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I'm not sure if the 90's are any different than the 110's, but on my 110, there are vacuum lines running around inside the dash on the passenger side. They control the heater/defrost flaps. So like Mike suggested, you might have a vacuum leak. You might play around with your heater/ventilation controls to see if it affects it. I believe there's also a cable that controls the fresh air inlet in the heater box. Maybe this is out of adjustment or not working.
Old April 19th, 2004, 07:12 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Sounds like you've got an ininvited passenger. Get your snake bite kit handy and lure him out with a salamander or lizard on a stick.
Old April 19th, 2004, 07:50 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
It might be associated with the air conditioner if you have one.
Just a guess.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old April 19th, 2004, 08:29 PM
P1CR
Mazen Fawaz
I think it increases when I'm slowing down, or stopped.
this is driving me nuts.
Maz
97' D-90 SW
Arles Blue
Old April 19th, 2004, 08:33 PM
here's a tangent but maybe powersteering? Or something with the AC?
Old April 20th, 2004, 11:42 AM
P1CR
Mazen Fawaz
ok, it gets more weird.
the hissing continues for a few seconds after I turn the key off, then fades away.
What a strange riddle. I like the snakes in my dashboard thought. At least I would know how to get rid of the problem.
Maz
97' D-90 SW
Arles Blue
Old April 20th, 2004, 04:21 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
It really does sound like a vacuum leak. The manifold vacuum is the highest when you're off throttle (idling/slowing), and it will bleed off if you have a leak when the source goes away (i.e. turning off the engine). A hose might've just come loose or maybe one of the ventilation damper actuators is leaking.
Old April 21st, 2004, 10:31 AM
P1CR
Mazen Fawaz
That sounds about right. How exactly do get to that stuff? Is it just under the hood? or does it need to get on a lift??
Maz
97' D-90 SW
Arles Blue
Old April 21st, 2004, 11:32 AM
Get under the hood and carefully feel/listen around for the noise. There are a bunch of hoses for the vacuum system, if you run your hand down the hoses you will feel a leak if there is one.
dash
Dash Rotted Out, Had to Fix It JimC Misc. Chit-Chat 7 February 6th, 2009 03:20 PM
New Defender Dash parts TDI Guy For Sale - Parts 1 April 3rd, 2005 10:58 AM
Dash install of radio paulb Defender Technical Discussions 3 December 17th, 2004 05:42 PM
Stereo Install In Dash caschumann Defender Technical Discussions 18 November 4th, 2004 12:41 AM
1997 Dash panel - what's there? ronward Defender Technical Discussions 6 April 26th, 2004 05:47 PM
