Occasional drip from my rear caliper - Defender Source
Old July 28th, 2010, 10:52 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I have a sporadic leak, a few drips once in a while from my rear driver side caliper. The caliper is off a 1997 Disco 1.
Old July 29th, 2010, 08:53 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
If the housing isn't to rusty just put a rebuild kit in it and call it done.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old July 29th, 2010, 09:06 AM
Any drip at all from your brake system is not something to put off. Get R done!
Old July 29th, 2010, 09:33 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Have you tried penicillin?
Seriously rebuild or replace your caliper.
Keith
Big, Red and ... aaa Red..
Old July 29th, 2010, 09:42 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Rear calipers are so cheap I'd just replace it.
Old July 30th, 2010, 06:46 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Best place to get a rear caliper? Should I not drive it till fixed?
Old July 30th, 2010, 10:39 AM
You are rolling the dice with any brake fluid leak. a little bit of fluid out can also mean a little bit of air in. and brake use is much heavier in rolling around town versus a long highway trip (which means more brake fluid loss in same amount of time.
your brakes will eventually get softer and softer, and if you have a failure of the seal, one day in traffic you could find your pedal hitting the floor with no effect and resistance as you approach that traffic light.
If you have any alternative, regardless of convenience, Iwould take it.
Let me ask you this, what is the level of leak you see in the caliper now? In military terms, there are 3 levels.
  • Class I: visible moisture but no accumulation or drip
  • Class II: visible moisture with accumulation (hanging drip) but no visible drip on the ground
  • Class III: visible moisture on the ground
Old July 30th, 2010, 11:06 AM
Napa etc. sell rebuilds on exchange basis.
Old July 30th, 2010, 11:38 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Ab has them in stock for 119
Old July 30th, 2010, 01:38 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Its a class 2 drip
Old July 30th, 2010, 01:54 PM
I would say you should replace no later than next week. The moment you hit class III, don't drive it. That's my opinion.
Old July 30th, 2010, 02:21 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Thanks a lot I appreciate all that typing. That would be an hour for me.
Old July 30th, 2010, 08:42 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I'm starting to think it might from the axel?
Old July 31st, 2010, 09:02 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Is it oil or brake fluid, smell it and see. The caliper is up top so I don't see how you could be dripping oil from it unless everything was coated in oil back there.
Old July 31st, 2010, 10:24 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
To be honest, I didn't look too close I just assumed it was the brake fluid, I had that problem with the old Axle. Whats the diff in smell?
Old July 31st, 2010, 10:25 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Gear oil has a nutty smell and color, brake fluid is thinner and clear.
Old July 31st, 2010, 01:58 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
But how does it taste?
Robert Deniro
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
