OBD2 Scanner help - Defender Source
Old August 6th, 2007, 09:32 PM
themaxx's Avatar
themaxx
Ade
94 ST
OBD2 Scanner help
Which OBD2 Scanner do you have? If you had to buy it all over again, what one would you get now and why?
I'm thinking about getting one and there is a few to choose from, they range from as cheap as $30 and they go up to as much as you wanna spend. 'You get what you pay for'...is this the case with OBD2 scanners? I'm thinking about getting one that connect to a laptop, is there any difference between them and handheld scanners?
I did a search on the topic of OBD2 and came across Equus and Rovacom as a good brand.
Ade
Old August 7th, 2007, 08:44 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
For basic code reading and erasing I bought a $125 one from Advance Auto Parts. It works very well on the Disco II that I work on. If you want access to all of the fuel curves, etc. then rovacom is the way to go but it is pricey.
inspection problem and OBD2 artm Defender Technical Discussions 25 August 31st, 2009 03:44 AM
OBD2 - P0420 Diagnosis pcscharfe Defender Technical Discussions 1 January 12th, 2008 02:28 PM
Newbbie OBD II ?'s Monkeyboy Defender Technical Discussions 13 March 9th, 2006 06:13 PM
where to find OBD2 socket steved90 Defender Technical Discussions 4 February 6th, 2005 04:52 PM
ECM Replacement?? Rob Defender Technical Discussions 2 November 24th, 2004 09:19 AM
» Defender Registry
B240 SNW
Sandt
Carlos
tom65
Add your Defender
