OBD2 - P0420 Diagnosis - Defender Source
Old December 23rd, 2007, 02:24 AM
pcscharfe
pcdefender
D90/NAS 110
Question OBD2 - P0420 Diagnosis
Today my 1997 D90 threw a "P0420" “Catalyst system efficiency below threshold” (Bank 1) code. It threw the same code exaclty 60 days ago... so whatever the problem is, it isnt going away.
My research on the web indicates any of the following causes:
An oxygen sensor is not reading (functioning) properly
The engine coolant temperature sensor is not working properly
Damaged exhaust manifold / catalytic converter / exhaust pipe
Retarded spark timing
Anyone have experience with this code? What was the resolution?
OBDII CODE READ-OUTS:
10/24/2007
P0420 – “Catalyst system efficiency below threshold” (Bank 1)
Freeze Frame Data:
Fuel Sys 1 – CL
Fuel Sys 2 – CL
Calc LOAD% - 46.6
ECT (f degrees) – 186
STFT B1 % 1.5
LTFT B1 % -12.5
STFT B2 % 1.5
LTFT B2 % -12.5
Eng RPM – 1866
Veh Speed – 41mph
12/22/2007
Fule Sys 1 – CL
Fuel Sys 2 – CL
Calc LOAD% - 40.0
ECT (f degrees) – 185
STFT B1 % 0.7
LTFT B1 % -15.6
STFT B2 % -2.3
LTFT B2 % -15.6
Eng RPM – 1909
Veh Speed – 57
Old January 12th, 2008, 02:28 PM
GYM's Avatar
GYM
Gary
97 SW
Hi Paul:
What was the resolution to your thrown code issue?
inspection problem and OBD2 artm Defender Technical Discussions 25 August 31st, 2009 03:44 AM
Trail break diagnosis phoenix37 Defender Technical Discussions 15 July 27th, 2009 02:41 PM
OBD2 Scanner help themaxx Defender Technical Discussions 1 August 7th, 2007 08:44 AM
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
where to find OBD2 socket steved90 Defender Technical Discussions 4 February 6th, 2005 04:52 PM
