O2 sensors disconnected. - Defender Source
Old July 24th, 2004, 10:20 AM
Marx-110
Simon Marxer
1993/Defender 110
I am curious, I fad my "Check Engine" light come on about a week ago. I finally got around to having a look around and found my O2 sensors were both unplugged from the harness. They must not have been replaced after I had the clutch put in about a week earlier. Anyway the light remains on, will it go off on its own or does it need to be re-set by a shop?
One more thing, I got some rear light guards from Atlantic British and the the bottom mounting location appears to be directly on a reflector! Anyone seen this before, could is this for a 90 only? I don't want to remove my reflector so I will probably just return them. Any ideas on either of these?
Old July 24th, 2004, 12:33 PM
Hmmm, well as far as ECM codes and check engine lights go read this for some better understanding
http://www.defendersource.com/faq/Engine/EngFault.html
There is a section in there on how to clear the codes but you can also disconnect the battery for 5 min and the codes will be cleared. I would reconnect the O2 sensors, clear the fault code and see what happens.
As far as the rear light guards, are they the square kind? If so they may have been crushed or squeezed a little during shipping and may need to be tweked a little to fit over the rubber reflector. If that is not the case do you mind taking a pic and posting back?
A little off subject but I see your in the same area of the contry as me (I'm in NH). If you ever want to go out and hit some trails just drop me a PM.
Old July 24th, 2004, 12:55 PM
Marx-110
Simon Marxer
1993/Defender 110
Thanks Mike, I will try the cut off switch thing right now. As far as the light guards They appear to be fine but I will have another look.
As far as hitting the trails, I think I am not in your leauge! Based on the photo you put on your signature I don't know if I could hang! Seriously that would be great. I will PM you if I am heading up your way maybe you could give me some ideas on good places to go for a "winch-less" rookie.
Thanks!
Old July 26th, 2004, 08:26 AM
Cool! I don't currently have a winch on the 90, allot of the trails I go out on have hard parts and bypasses so a guy with a stock 110 can go down the same trail. I'll PM you when I go out on a not so bad trail.
disco, sensor
110 Kills Multiple O2 Sensors pcscharfe Defender Technical Discussions 8 May 20th, 2009 10:19 AM
4.0 OBDII factory Bosch O2 sensors RoverC For Sale - Parts 5 June 4th, 2008 11:36 PM
NRP Y-pipe & with O2 sensors for D90 Barnett Childress For Sale - Parts 0 May 29th, 2005 06:52 AM
Driveshaft weights? Help! P1CR Defender Technical Discussions 11 June 30th, 2004 02:16 PM
O2 sensors J4hand Defender Technical Discussions 0 January 8th, 2004 02:39 PM
