O2 sensors - Defender Source
Old April 5th, 2007, 11:41 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
O2 sensors
HOw do I know if my O2 sensors are bad? Is it recommended that they are replaced after so many miles or do they go bad and then you have some symptoms with the performance of the engine? Can I have a diagnostic test done to determine if they are good or not? Sorry but I am clueless when it comes to these o2 sensors.
Old April 5th, 2007, 02:30 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
The ECU is likely to throw a code if the O2 sensor is bad.
On the newer O2 sensors (like yours), the ECU will also throw a code is the heating element is bad (not as reliable on the older style 3-wire sensors).
The best is to plug a monitor to your OBD-2 plug and watch the sensor output to verify it is switching properly.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old April 5th, 2007, 10:42 PM
andyrad
Andy Radlgruber
None.
I have a '94 with the older OBD1 sustem and I was told that the service engine light comes on at a pre set amount of Kilometers. It did, and it's purpose is to tell you to replace the 02 sensors. It was around 70 or 80K. That's metric for you south of the border, do the conversion. We also have a code display in the passenger footwell next to the computer that is a dream. Mine was telling me I had a faulty left bank Lambda(02) sensor. The engine ran rich and rough at idle in the summer, very poor fuel economy. Once I changed the sensors it was a new truck. Elvis runs like a top. To make a long story short, don't be cheap about these things. Replace them. They do go sideways on you and you will probably not notice the difference until after you change them. There is a lot of info about how to test them and make sure it is the 02 sensors causing the problem and not something else but you will need some patience to do it. Go to a site like oxygensensors.com and source your parts. Mine were only $105 a piece but I have the three wire jobs.
After all, you own a Land Rover. Don't be cheap and try to save $100. It's a lot easier to just do it.
Some people are so heavenly minded that they are NO EARTHLY GOOD!
Old April 5th, 2007, 11:48 PM
MonLand
Loic Fabro
That's correct the "Service Engine" light is to replace the cats (and O2 sensors while you are at it).
The "Check Engine" light comes on when O2 sensor (or other emission-related problems) are detected by the ECU.
That applies to the OBD-2 (1996+ vehicules) as well.
On the 1997, if you are willing to splice the wires, you can use also a few generic replacement or get some Nissan Altima (year? can't remember) O2 sensors. Last I checked, they were in the $60-$80 range (and that time the stock LR sensors where in the $130 range..... multiply that by 4 as you are "supposed" to replace all of them at the same time because they are supposed to wear evenly, that the difference is worth the effort; wire colors were the same).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old April 6th, 2007, 01:48 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
I heard the rear sensors on the '97's were jsut to check that the cat's were working, and aren't as important to engine performance as the fronts.
sensor
110 Kills Multiple O2 Sensors pcscharfe Defender Technical Discussions 8 May 20th, 2009 10:19 AM
NRP Y-pipe & with O2 sensors for D90 Barnett Childress For Sale - Parts 0 May 29th, 2005 06:52 AM
O2 sensors disconnected. Marx-110 Defender Technical Discussions 3 July 26th, 2004 08:26 AM
Driveshaft weights? Help! P1CR Defender Technical Discussions 11 June 30th, 2004 02:16 PM
O2 sensors J4hand Defender Technical Discussions 0 January 8th, 2004 02:39 PM
