O2 sensor replacement / ECU "break in" - Defender Source
Old August 18th, 2015, 08:49 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
Changed my O2 sensors today as I think it is related to an intermittent cut out issue I'm experiencing and it running lean/backfiring.
Question: After replacing O2 sensors in a 1994 NAS D90 does the ECU need time to adjust to the new sensors?
Reason I ask is it is experiencing a little cut out of power (But different than I was experiencing before) after test driving it. I drove it for about and hour this afternoon and it did it a couple of times.
Thoughts?
Thanks!
Will
Old August 18th, 2015, 08:53 PM
Originally Posted by wmatos1001 View Post
Changed my O2 sensors today as I think it is related to an intermittent cut out issue I'm experiencing and it running lean/backfiring. Question: After replacing O2 sensors in a 1994 NAS D90 does the ECU need time to adjust to the new sensors? Reason I ask is it is experiencing a little cut out of power (But different than I was experiencing before) after test driving it. I drove it for about and hour this afternoon and it did it a couple of times. Thoughts? Thanks! Will
no break in time ... Probably loose air hose.
Old August 18th, 2015, 09:49 PM
wmatos1001's Avatar
wmatos1001
William
Thanks I will check hoses.
ac, ecu, sensor
2 4.2 ECU's 1 3.9 ECU eliaschristeas For Sale - Parts 3 June 19th, 2013 03:15 PM
Oxygen Sensor Replacement PDX Bolt Defender Technical Discussions 4 September 4th, 2010 07:50 AM
Need an ECU... looking for the ECU out of a 95 Disco or equivalent IPSC_GUY Wanted 7 February 16th, 2010 04:36 PM
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
O2 Sensor replacement Coiler Defender Technical Discussions 2 June 22nd, 2005 01:55 PM
