O2 sensor replacement - Defender Source
Old April 19th, 2015, 10:16 AM
mitchbuckner
Mitch
97 D90
Hi,
Any suggestions on where to buy the O2 sensor replacements online? Atlantic British has a pack of four for almost 500 bucks! Is it worth it to go with theirs? I assume they are Land Rover parts? I found NGK 25044 kits on eBay that say they fit 97 D90's as well...for only 56 each. Should i save half the money and buy the NGK's?
Thanks for any help
Mitch
Old April 19th, 2015, 10:53 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Originally Posted by mitchbuckner View Post
Hi, Any suggestions on where to buy the O2 sensor replacements online? Atlantic British has a pack of four for almost 500 bucks! Is it worth it to go with theirs? I assume they are Land Rover parts? I found NGK 25044 kits on eBay that say they fit 97 D90's as well...for only 56 each. Should i save half the money and buy the NGK's? Thanks for any help Mitch
How many sensors do you need? I just did both of mine in the range for $220 from AB. There are always two different products listed. One will be ridiculously expensive and I assume is original equipment. The other is just as good, in my opinion, and is reasonably priced.The O2 sensor's are NTK. NGK are spark plugs. Both Japanese. Hard to go wrong. My .02
Old April 19th, 2015, 06:56 PM
mitchbuckner
Mitch
97 D90
Thanks David. I am going to replace all 4. The quote from AB was 480, so based on your price of 220 for 2...that sounds right.
Thanks for the reply
MItch
Old April 19th, 2015, 07:15 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The difference in the generic ones are the plugs. If you want to get a factory connector you are going to pay over $100.00 each.
Old April 19th, 2015, 11:54 PM
WG_moots
Wilmer
I just replaced both of the ones on my '95 Defender. Got them from Rovers North for about $135 a piece plus shipping. You will need the round connector, as stated above, you will have to splice the wires and use the connectors from your current sensors if you go with the generic (cheaper option).
Old April 20th, 2015, 12:06 AM
lucky8 has them too (under the range rover classic parts section) for $95/each
Oxygen Sensors
these are the round ones from the looks of it..
95' D90 - daily driver..
Old April 20th, 2015, 12:14 AM
D90Overkill
David Frank
1995 ST #2615
That there is a screaming deal! Looks just like the ones I just installed for way cheaper! Nice find! Where were you a week ago! ;-)
Old April 20th, 2015, 01:44 AM
psykokid
Jake
1997 Disco
I used NTK ones on mine when I did a full tune up before smog a few years ago. When i took out the OE sensors they were NTK with a rover part number on them iirc. For AEL trucks the part number is 25044 which is about 50 bucks on amazon. For non AEL trucks the part number is 25017 and they are bout 80 on amazon currently. My truck has AEL so i used the 25044 sensor and it had the correct plug, no generic plug splicing bs. Plug and play..
Old April 20th, 2015, 06:20 AM
If you don't mind splicing on the old wiring plug, you can get them on ebay for about $30 each. Genuine NTK.
ac, sensor
Oxygen Sensor Replacement PDX Bolt Defender Technical Discussions 4 September 4th, 2010 07:50 AM
O2 Sensor replacement Coiler Defender Technical Discussions 2 June 22nd, 2005 01:55 PM
OEM MAF sensor from '97 D90.... dmarchand For Sale - Parts 4 June 18th, 2004 06:49 AM
OXYGEN SENSOR Question? ... Vendor ? norros Defender Technical Discussions 4 June 7th, 2004 07:14 PM
Anyone shear an O2 Sensor Ragland Defender Technical Discussions 2 May 24th, 2004 08:37 PM
» Defender Registry
Rosa
fruitpunch
#894
MyD90
Add your Defender
