o2 Sensor Recommendation for 95 NAS? - Page 2 - Defender Source
Old July 24th, 2014, 03:17 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
Originally Posted by Jymmiejamz View Post
Let me know how they work out for you Brad, I need one too!
Need a left one as well.
Old August 4th, 2014, 10:14 AM
bradfordish's Avatar
bradfordish
Bradford
95 D90 SW #141
Got the NTK o2 sensors installed and am very happy with them, but how do you clear the check engine light?
Old August 4th, 2014, 10:16 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
I could be wrong but just leave the battery unplugged over night, someone with a lot more knowledge will tell you better.
Old August 4th, 2014, 10:26 AM
fuel injection fault display provides two-digit diagnostic codes in a way that's very easy to read: the display has a dark red, transparent, molded plastic case. Light emitting diodes can be seen through the side of the case when a fault code is displayed. Nifty!
If multiple faults exist, the display shows the one that the ECU thinks is highest priority. Higher priority faults need to be "cleared" before lower priority faults will be displayed. A "blank" (dark) display usually indicates there are no faults.
Use this procedure to clear faults:
1. Switch "on" the ignition.
2. Disconnect the serial link mating plug, wait five seconds, and reconnect.
3. Switch "off" the ignition, and wait several seconds.
4. Switch "on" the ignition. The display should now reset.
Note: It should either show a lower priority fault code or appear dark.
http://www.britishv8.org/articles/rover-14cux-efi.htm
Old August 4th, 2014, 11:20 AM
bradfordish
Bradford
95 D90 SW #141
Awesome. Thanks Jason.
Old August 4th, 2014, 12:53 PM
If you disconnect the battery for a couple seconds the faults will clear.
Old August 4th, 2014, 02:19 PM
but you won't get to learn all the amazingly useful codes reported ...
Old August 5th, 2014, 08:39 AM
bradfordish
Bradford
95 D90 SW #141
After several attempts, I couldn't get it cleared using the fault clearing procedure, but disconnecting the battery did the trick.
Old August 5th, 2014, 09:47 AM
budzny
Real4X4
NAS 97 ST/NAS 93 110/62
Birthday Committee Team
Always work on me.
Sal
Old October 29th, 2014, 01:06 PM
COSteve
Steven Reed
93 Defender 110 - #107
Is OEM for Landrover Defender 90 and 110 NGK or Bosch?
Has anyone used the approach of cutting / soldering in the connector to the universal O2 Sensor?
http://www.magnumtuning.com/en/detai.../defender/3-9l
Old October 29th, 2014, 02:19 PM
robertf
Robert F
1995 Discovery
I believe Bosch is oem. Those universal o2 sensors won't work. Rovers use Titania based sensors not zirconia, the behavior of the 2 is not interchangeable. Not only that but the threads are different.
Old October 29th, 2014, 02:54 PM
These work great:
http://www.ebay.com/itm/141302776001...%3AMEBIDX%3AIT
You have to change connectors.
Old October 31st, 2014, 10:54 AM
COSteve
Steven Reed
Summary...
Current (10/31/14) purchase Options - Amazon Defender O2 Sensors - NTK vs. Bosch
EBAY above NGK (change the connector) currently 31.75 per plus shipping....
Bosch 13946 Oxygen Sensor, OE Type Fitment (with round OEM Connector / no cutting)
http://www.amazon.com/dp/B001D0FMPO/...=IYRAMZPVM0J8U
Includes three OE Titania wires
Cost - 95.16
NGK 25016 Oxygen Sensor - NGK/NTK Packaging
Part number at other sites show this as the correct connector / no cutting
http://www.amazon.com/NGK-25016-Oxyg...productDetails
Amazon Cost - 79.48
http://www.summitracing.com/parts/ngk-25016
Summit Racing Cost - 101.00
Looks like a no brainer at this point... NGK is OEM.... no cutting.. 80.00 a side ...
Am I missing anything here?
COSteve....
95, nas, sensor
Company Recommendation Viton Defender Technical Discussions 9 June 3rd, 2012 12:37 AM
Winch Rope Recommendation (for XD9000i)??? limeport Defender Technical Discussions 9 June 22nd, 2009 05:30 PM
Shock brand recommendation Rubicon21 Defender Technical Discussions 3 September 25th, 2007 05:31 PM
Jack Recommendation TDI Guy Misc. Chit-Chat 16 April 5th, 2006 12:43 PM
Recommendation on a Fire Extinguisher - size, type, mounting, etc. COSteve Defender Technical Discussions 16 April 16th, 2004 02:21 AM
