O2 sensor question - Defender Source
Old March 8th, 2011, 02:37 PM
Defender90_218's Avatar
Defender90_218
Trenton Smith
1997 D90
O2 sensor question
Quick question I couldn't find by searching,
Where are the front O2 sensors on the '97 4.0L and how long does it take to change them?
Old March 8th, 2011, 02:47 PM
Naplm00
Matthew
in general terms, you will have one in front and one behind the cats on 96 and up vehicles
Use a offset 21mm 02 plug socket and some heat to remove them.
the harbor freight one is cheap and works fine
http://www.harborfreight.com/3-8-eig...nch-97177.html
Old March 8th, 2011, 02:56 PM
dchapman
Daniel Chapman
1999 D1
Sometimes it's a 15-minute job, other times it takes 2-days.
Old March 8th, 2011, 03:25 PM
Whatever you use, make sure it is 6 point and spray the crap out of them with your pentrating lubricant of choice before hand. I put anti-sieze on the threads when I reinstall.
If you know they are junk, my best luck has been cutting the wires and using a proper 6 point deep socket and a breaker bar to get them out.
Old March 8th, 2011, 03:33 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
For the senors, Amazon used to be the cheapest place to get them, but now it looks like it's:
http://www.autopartsdealer.com/ntk_o..._content=rank1 if you don't AELS. Free shipping too.
If you have AELS then the same place is cheaper than Amazon by a few cents, but no free shipping:
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
sensor
O2 sensor question ember Defender Technical Discussions 1 July 30th, 2010 07:54 AM
Surplus O2 Sensors thecatsmeow For Sale - Parts 0 March 16th, 2010 01:05 PM
O2 Sensor troubleshoot floatflyer Defender Technical Discussions 2 November 7th, 2009 09:34 PM
Anyone shear an O2 Sensor Ragland Defender Technical Discussions 2 May 24th, 2004 08:37 PM
O2 sensors J4hand Defender Technical Discussions 0 January 8th, 2004 02:39 PM
