O2 Sensor Longevity... - Page 2 - Defender Source
Old March 11th, 2006, 03:56 PM
Antonios
Antonios Hadjigeorgalis
No more
OK, Back to the Oxygen sensors.
I just tested mine using the method outlined in the EFI test procedure:
http://www.rangie.com/files/167_394.jpg test #27, 27a
http://www.rangie.com/files/167_395.jpg Test #27b
I only did test 27b since it was simple and I was clear on what was necessary. What's not so clear are the results.
Both results were changing the whole time. The left hand result was staying at .013V quite a bit and fluctuating up to .8-.9V. The right hand result was fluctuating constantly from .023V-1.250V
I'm not exactly clear on how to do tests 27 & 27a.
On 27 it shows the ohm meter connected between the #4 wire and the 87A slot of the fuel pump relay plug. There is also a line connecting wire #4 to the 85 slot of the relay plug. Does this mean it needs to be connected with a separate wire while performing the ohm meter test?
On 27A, it shows a loop between 87A & 30 in the relay plug. Like above I assume that means they need to be connected while measuring the volts at the O2 sensors, correct? And how exactly do I test the voltage at the O2 sensors? Do I have to go through the insulationon the wires?
Miami, FL
Old October 3rd, 2007, 09:01 PM
Antonios, what was the outcome of this? Did you get it resolved?
I have the *exact* same symptoms and it's happening way too frequently for comfort now. Practically every time I drive it this happens at least once. Last night it happened and I noticed this time that I heard a relay click right before the rough running/low idle/fuel smell/stall condition, and then a click before it returned to normal.
thanks
charles
Old October 3rd, 2007, 09:05 PM
Antonios
No more
The really bad running was solved by replacing the vehicle speed sensor. BUt I was still getting the occasional stall. The occasional stalling stopped when I swapped my O2 sensors left to right. I was going to replace them but I thought I'd try swapping them first and it never stalled again.
Miami, FL
Old October 3rd, 2007, 10:02 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Problem gone is always a good thing!
Hopefully it will stay that way.
My oil line fix
My 100k stopped odometer fix
Old October 4th, 2007, 08:01 AM
Thanks. Is there any way I can isolate it down to the VSS? My O2 sensors are new to me, but supposed to be god. I guess I can swap my old ones back in to see if anything changes. Otherwise I'll just replace the VSS and go from there.
thanks
charles
Old October 9th, 2007, 10:32 AM
I can't find the VSS on my 94! Is it the little box mounted to the drivers side frame that the speedo cable goes into?
Old October 9th, 2007, 11:00 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
thanks
charles
I have a set of (old) o2 sensors you can borrow if you want. They are not new but appeared functional to the seller. I assume that you old ones are good too?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 9th, 2007, 11:14 AM
Yeah I can try swap out my old ones as well. I just wanted to take a look at the VSS and see if there were any visual signs of problems.
I might want to try swap a few parts with you if you willing though - stepper motor, tps or whatever makes sense to try
thanks
charles
Old October 11th, 2007, 06:13 PM
Well swapping the O2 sensors with my old ones hasn't helped so I guess I'll replace the VSS. Let hope I'm just not throwing parts at the thing.
Old October 16th, 2007, 08:04 PM
$125 down the drain. Just got a code 03 but that appears to be related to the memory clearing.
dag nabbit.
Old October 22nd, 2007, 11:51 PM
Bugger. I thought I had this licked after finding some small holes in the air intake tube between the maf and intake as it ran without incident for a few days. Yesterday It happened again with a code 44 thrown (Lambda sensor A - left bank).
sensor
O2 Sensor troubleshoot floatflyer Defender Technical Discussions 2 November 7th, 2009 09:34 PM
110 Kills Multiple O2 Sensors pcscharfe Defender Technical Discussions 8 May 20th, 2009 10:19 AM
O2 Sensor Removal w/ LRT-12-047 pcscharfe Defender Technical Discussions 9 November 13th, 2008 12:30 PM
Anyone shear an O2 Sensor Ragland Defender Technical Discussions 2 May 24th, 2004 08:37 PM
O2 sensors J4hand Defender Technical Discussions 0 January 8th, 2004 02:39 PM
