o-ring materials for gasoline and brake fluid ? - Defender Source
Old April 19th, 2013, 05:26 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I'm changing o-rings on V8 injectors and also on ABS pump shuttle valves and pump valves.
I've been thru a few reading about o-rings material and it's more complex than I thought.
Anyone familiar with the subject ?
I guess I'll stay on the safe side and use Buna (NBR) for the gasoline and Ethylene Propylene (EPDM) for the brake fluid.
Thoughts ?
Cheers
- Charles Eames
Old April 23rd, 2013, 03:13 PM
mattwhite
Matt White
94 D-90
I'll take a stab at this. I'm not an expert but this may help:
http://www.mcmaster.com/#o-rings/=mg6m8w
Click on the link at the top "General Properties of O-rings". Note mcmaster properties are not the bible, so I usually double check the properties they list.
Matt
brake, gas
Finding Series Brake Fluid in NOVA Bricktop Series Technical Discussions 15 November 30th, 2012 11:18 AM
Brake Fluid Resevoir leak Lriwater Defender Technical Discussions 13 December 3rd, 2010 08:37 PM
Brake fluid leaking into servo? easy Defender Technical Discussions 3 August 3rd, 2009 04:55 PM
Replacing brake fluid Antonios Defender Technical Discussions 2 September 27th, 2006 09:09 PM
