O.K so my update on the air cleaner question flew like a lead zepplin - Defender Source
Old April 29th, 2008, 07:55 PM
CDeWan
Clay DeWan
5.3L beastie
Question O.K so my update on the air cleaner question flew like a lead zepplin
Since it didn't fly the first time, consider the following in an english accent - it works for Les at Rovers North (Les if you read this....upmost respect).
1. Since I am more in a desert climate I decided to remove the air cleaner cover to get more air flow into the intake? Anyone see a problems yet?
2. Has anyone tried successfully I hope to go with placing the aircleaner closer to the wing vent or know of a kit (since I am lazy) that already has the bits and bobbles.
Result is trying to get more mpg out of a 3.9L and am thinking colder air would help a little.
Old April 29th, 2008, 08:34 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
What about a snorkel with a precleaner? Bring it up to the roof line so you avoid a lot of the dust, and the dust that gets to it, gets a shot through the precleaner before it hits the regular filter.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old April 29th, 2008, 08:53 PM
CDeWan
Clay DeWan
5.3L beastie
hmm.... not a bad idea, do those kits relocate the Mass Air Sensor (or AMM). Thank you.
Old April 29th, 2008, 10:47 PM
A precleaner isnt going to help your fuel milage, you can't use it in lieu of the air filter. I totally don't follow the desert-climate-remove-cover-increase-flow theory. You're sucking the same amount of air through a larger opening.
Not familiar with cold-air-induction for a defender, but perhaps you might have some luck with a discovery air filter box and some piping if you simply want to try and relocate the intake for a colder air charge.
Old April 29th, 2008, 11:49 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
You do all those little tricks and 2hp would be a victory. Probably less.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 30th, 2008, 12:01 AM
CDeWan
Clay DeWan
5.3L beastie
Jim,
o.k so precleaner is rulled out. money saved. Thank you good advice.
The same volume of air through a larger whole will increase the efficiency (less drag) on the intake stroke of a 4 cycle engine, thus using less HP to fill the cylinder -minor, gains in efficiency. Desert climate comment means rain or water is much less of an external factor in my decision being in San Diego. Due to the fact that the ambient air temperature is hotter and dryer the compounding effect of the ambient outside temperature in the summer with the heat coming off the engine affecting the air temperature going into the engine from the air cleaner located in the back of the engine compartment leads to a less efficient power stroke of the motor hot outside + hot inside air.
What I am looking to pick other D-90 owners brains "has anyone moved their air cleaner or air cleaner box close to the wing vent (or other external opening) in order to increase the effieciency of the intake stroke to obtain the best possible flow into the throttle body.
Thank you for the info on the discovery box, I will take a look at its demensions next time I am in the junkyard.
Old April 30th, 2008, 12:07 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Originally Posted by CDeWan
Jim,
We all know what your trying to do. It's been tried. What I am saying is it will not do anything for you. It's waisted time. If you want actual gains in HP you need to look elswhere. If you want a neato project, then knock yourself out.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 30th, 2008, 03:03 AM
CDeWan
Clay DeWan
5.3L beastie
Gains in HP is not really my objective, and my main objective running cooler with an aluminum block engine in a hotter environment is more of my push. Hopefully I will hear from someone who has tried and has picture or something rather than shooting down my nice pretty balloon. Maybe my head won't hurt so bad after I knock myself silly.
Old April 30th, 2008, 08:42 AM
Eric_S
Eric
'97 D-90 ST #1507
Give these guys a call. http://www.ramairbox.com/
They make ram air intakes for muscle cars and hot rods. They should be able to help you design something.
I seen lots of debates on where the best place to mount the opening for an intake to get the best ram effect and the consensus is the front of the vehicle is the best place ('68-'69 Oldsmobiles had scoops mounted under the font bumper). I've seen people post on other web-site (take this info with a gain of salt) that having the intake on the hood ('70-'72 Oldsmobile set up, similar to where the wing intake on a D90 is) there is actually negative pressure there.
Having the intake low on the front of the car isn't a good idea in a dusty environment. You'll be sucking in too much dust. That's where a snorkel will help out but there are too many twists and turns in that set up to see any HP gain.
Good luck and keep us posted.
Old April 30th, 2008, 09:40 AM
There is something called the "air force one" which I believe was made for D-90s. Basically get a KN cone filter and bolt it to the MAF with a shorter hose.
Ron
PS not great for wading through streams
Old April 30th, 2008, 10:14 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Rover Accessories used to sell that setup though I don't see it on their site any longer.
Old April 30th, 2008, 10:36 AM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
To reduce the amount of dust getting to my K&N air filter inside my air cleaner canister I installed a Mantec raised air intake. It was originally designed and used for desert use (Although it is commonly called a snorkel it is NOT for wading through rivers or streams - many people do buy and use them for that reason). The raised air intake draws air from outside the vehicle at ambiant air temps and directs it directly to the air cleaner canister. As soon as I made this change I noticed my oil stays alot cleaner. Even though I regularly cleaned my K&N I guess dirt was still making its way into my motor / oil. The raised air intake really does make a difference in how clean your oil stays. I found that the new intake neither hurts nor help measureable gas mileage. The best way to save on gas is to remove any lead that my be hiding in the sole of your right shoe.
Old April 30th, 2008, 11:01 AM
GYM's Avatar
GYM
Gary
97 SW
Originally Posted by Eric_S
...having the intake on the hood ('70-'72 Oldsmobile set up, similar to where the wing intake on a D90 is) there is actually negative pressure there.
Exactly. The issue with the muscle car era hood mounted forward facing scoop openings is that they were not high enough to grab undisturbed air flow. Look at any modern day NHRA Pro Stocker. The air box opening is, what, maybe 9 to 12 inches above the hood line?
(Probably not a good look for a D...)
Old April 30th, 2008, 11:44 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Maybe I am missing something here, but why not just get an oil cooler? Beat hacking up the intact for marginal gains and it'll be much more effective than moving the filter 2 inches or so...
Old April 30th, 2008, 01:00 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I think I know what he's getting at...... he is trying to avoid sucking the hotter than hell underhood air into his engine. Something I've considered a lot about how to do, but could never come up with a setup I liked enough to start making changes underhood.
Another issue is that if you are trying to get cleaner air into the engine, then don't use a K&N filter. Every test I've ever seen on the things proves that they do flow more air, but also allow a lot more stuff to pass through the filter. When I get around to a new engine, I'm going back to the paper filters to protect it.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 30th, 2008, 04:25 PM
Eric_S
Eric
'97 D-90 ST #1507
Originaly posted by Hans
....think I know what he's getting at...... he is trying to avoid sucking the hotter than hell underhood air into his engine...
That's my understanding of his question too.
But some places are better than others to mount an intake with respect to weather the air will be forced into the intake tubing or if the engine will have to overcome negative pressure. And he's also worried about dust too. That pretty much limits him to "raised air intake" (I miss-spoke when I called it a snorkel earlier, thanks for correcting me Len ).
Old April 30th, 2008, 05:27 PM
CDeWan
Clay DeWan
5.3L beastie
Guys...... this is exactly the discussion I was looking for and it is very much appreciated and there is definitely food for thought especially about the negative air pressure on the wing...did not think of that.
Also, the I like the oil cooler suggestion to as I have the fitting for the LT85 trasmission but not the lines and the cooler. Can I grab any of these from a Diso or a classic? The reason I ask is that these vehicles are now coming through the pick your part junkyards which means they parts are at a bargain prices. I picked up the 4.2 ECU for $40 the other day. and would be happy to keep my eyes open for stuff.
And once again - Thank you guys for your input. I appreciate a forum that fosters new (or revisits old) ideas with uplifting suggestions rather than "no it can be done attitudes"
Old April 30th, 2008, 06:48 PM
Hans's Avatar
Hans
Hans Haase
I have wondered from time to time, if just punching some louvers in the hood close to the windshied would be sufficient. That is a high pressure area on most cars (I haven't tested on a D90 to confirm).... so it would act like a cowl induction possibly and force some cold air down into the engine compartment right on top of the intake.
Then again, it would necessitate a full hood repaint, and I worry about water dripping down in that area.
-Hans
My oil line fix
Old May 1st, 2008, 02:20 AM
I've always thought the hood was a high-pressure area, but I can't say why I know this or where I found it out. I'm sure its dependent on the aerodynamics of a particular shape, but it would be nice to find out. I think the pro street cars and such run huge scoops for engine clearance, not air flow.
Old May 1st, 2008, 03:48 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Getting rid of the cats under the hood really cuts down on under hood temps-I'm just saying here. At 280,000 miles you are due a little extra emissions. That car is saving itself being replaced close to three times now. Think about it! Our vehicles are the last of their kind. Modular to stay alive indefinitely. If Ta ta can keep it going.
Last of their kind worth driving IMO
legend in my own mind
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
3.9L Air Horn / Air Cleaner Cover Wolf Fabrication Wanted 0 November 3rd, 2008 08:10 PM
Air Conditioning Parts Question for 1995 D-90 Retrofit Heath Defender Technical Discussions 2 May 25th, 2005 02:54 PM
AIR COMPRESSOR Question: norros Misc. Chit-Chat 8 March 21st, 2005 03:28 PM
