Nylock nut size, rear flange of transfer case - also identify T-case ratio - Defender Source
Old July 10th, 2012, 08:12 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Does anybody know the nut size for the 4 bolts on the rear flange of the t-case? Where the front of the rear propshaft bolts to? I need to order one.
Also, Can anybody help me identify the ratio in my t-case? Serial # 28D442905E
so as per Ashcroft's site that makes it a 28E which I can't find the ratio of. (I'm guessing its 1.2 but wanted to be sure). I think mine needs a 1.4 to get going a bit better.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old July 10th, 2012, 08:14 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
No based on your number it's a 28D (1st 3 digits), and that would make it a 1.2.
Can't remember the size of the nuts off hand but I normally just order them from one of the normal LR parts places. Not sure if you will be able to find them locally as they are a funny thread size. Fine thread.
Old July 11th, 2012, 12:53 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
3/8-20 is a British Standard Fine thread and is NOT the correct size. That is the size of the bolts on the bottom of the diff.
The TC/DS bolts are 3/8-24, available at most any good hardware store, or a bag of grade 8 can be had from McMaster for pretty cheap. The bolts are 1.25" long and are pricey because of the odd size. You can buy 1.5" bolts and zip the end off, just be sure to chase the threads when you're done.
Old July 11th, 2012, 02:42 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
danke, will work on this tonight.
~2008 GTI TSI
transfer case
1.2 ratio transfer case for 1995 Disco dave_lucas Wanted 3 August 13th, 2010 12:57 PM
Ashcroft transfer case upgrade pcarey Defender Technical Discussions 15 November 10th, 2005 02:15 AM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Transfer Case jimmy salmon Defender Technical Discussions 2 September 15th, 2004 10:18 PM
Transfer Case Lever Thread Size? ronward Defender Technical Discussions 4 August 30th, 2004 02:26 PM
