Nuts and bolts ... - Defender Source
Old August 6th, 2007, 07:39 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Nuts and bolts ...
Does anyone know where to get these original (or similar) metric flanged bolt. I can find all non metric types here but when it comes to metric everyones has the deer in the headlights look on their faces.
An internet provider would be great.
Thanks !
Pat
Kirk Lazarus, Tropic Thunder
Old August 6th, 2007, 08:38 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Don't know what size you're looking for, but you might try this place:
http://www.metricspecialties.com/Shop/products.htm
Old August 7th, 2007, 01:55 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
mcmaster.com
fastenal.com
nutty.com
- Charles Eames
Old August 7th, 2007, 09:26 PM
Retrofit's Avatar
Retrofit
Pat
Thanks ...
Thanks for all the links, but tried them all with no luck.
I'll keep on looking !
Pat
Old August 7th, 2007, 09:30 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Pat - What size are you looking for? I saw them on the Metric Specialties site from M6 to M10. If you contact them, they might be able to get other sizes.
Old August 8th, 2007, 01:04 PM
61rover's Avatar
61rover
John Crouse
Metric Fastners
I've used these guys and they haven't dissappointed yet:
AAA Metric Supply Incorporated
60 Lipan StDenver, CO 80223-1526
(303) 892-9000
www.aaametric.com
Old August 8th, 2007, 01:25 PM
Call mike at LR West Chester. He will get you the genuine ones.
Old August 8th, 2007, 09:39 PM
Retrofit's Avatar
Retrofit
Pat
Phone calls ...
Thanks for all your help, I will be making phone calls on friday to get what I want and I am sure one of the above has what I am looking for.
Pat
Old August 11th, 2007, 05:39 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Ok, I'm going to hijack this thread, since it looks like it's over anyway.
Does anybody know what kind of nut holds the spark plug wire loom to the water pump? It's a little, black 11mm guy and I accidentally dropped it down into some dark hole in the engine bay and it's good-as-gone.
thanks,
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
bolts
Check your chassis/bulkhead bolts! chris snell Defender Technical Discussions 7 July 13th, 2012 08:57 AM
ROAV Summer Nuts and Bolts Rally July 31-August 2 ukoffroad Trips, Trails and Events 16 August 4th, 2009 12:44 PM
What thread pitch are the big bolts on the tire carrier and the lug nuts? evilfij Defender Technical Discussions 5 April 20th, 2009 02:38 PM
Door Sill (Carpet) Trim - D90 Wagon Kimos Defender Technical Discussions 14 October 28th, 2004 08:55 PM
Stripped nuts on the driveshaft... dmarchand Defender Technical Discussions 13 November 18th, 2003 09:41 PM
