'Nuther Won't Start Thread - Page 2 - Defender Source
Old April 20th, 2009, 01:37 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by evilfij
Did you replace the silver relay for the computer? Try swapping them and see if the fuel pump still runs.
Ron
Let me try that - once the rain/wind dies down.
Old April 27th, 2009, 12:41 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
UPDATE:
My dad came into town and helped me out. Main thing he noted was that there was a weak spark. I had ordered a Mallory kit anyway so we installed it and it started up. Maybe a broken module inside the original distributor?
Check Engine light came on with Code 44. Cleared it this morning and drove the truck on a short drive and it hasn't come back on.
My dad said to change the oil as a little gas might have gotten into the pan. It was needing a change anyway and I figure it wouldn't hurt.
I will probably end up getting new plug wires as the ones that were on it don't seem to fit the Mallory cap all that great. What have people used with Mallory setups? Does Magnecor work well?
One thing I noticed was with the new distributor and coil setup that the truck fires right up better than it did before. The only downside is that the idling seems a little off - idles high coming to a stop sign for a moment and then low after it stands for a bit. Maybe the plug wire isn't making a great connection?
At any rate, it's great to have it running and I really appreciate the help from the board. I probably ended up spending a little more on some extra parts but I learned more about the ins and outs of the truck and from what I've read the Mallory setup should be a bit more stable/stronger than the stock distributor and coil.
start
YANST (Yet Another No Start Thread) - fuel pump circuit issues cgalpin Defender Technical Discussions 25 August 2nd, 2009 11:23 PM
HELP! another won't start thread... stuck in Boulder bharris Defender Technical Discussions 25 January 12th, 2009 09:59 AM
Another 'my truck won't start' thread Black_and_Blue Defender Technical Discussions 14 January 25th, 2007 07:17 PM
Transfer Case Lever Thread Size? ronward Defender Technical Discussions 4 August 30th, 2004 02:26 PM
Thread rating options chrisvonc Community News & Announcements 0 July 2nd, 2004 09:49 AM
