Nuked my lighting! - Defender Source
Old February 28th, 2011, 11:33 AM
partisanjager42
michael B. Lube
1994 Defender 90
Question Nuked my lighting!
Well there I was-
Installing My stereo in the Mud Counsel the previous owner was kind enough to install in my My 94 D-90 NAS. I Crossed a wire in the bundle for the hazard lights. Now here is what happened-
NO Headlights
NO directionals
NO Power to the Stereo
ARB lockers & compressor down!
So I started to change Relays hoping thatg was the issue! the center Relay below the cab's fuse block between the x2 yellow relays were missing? So I replaced it. then next time I turned the key the Headlights & directionals switch melted! and the fuse box ground melted. Wow i'm lost!
Normally I'm not bad at this! but this this has more cross wiring that the Millennium Falcon!
Case of beer to the hero who figures this one out!
-Michael
Old February 28th, 2011, 11:52 AM
dchapman
Daniel Chapman
1999 D1
Step 1 = http://www.expeditionexchange.com/ca...5&cat=0&page=1
Step 2 = http://www.expeditionexchange.com/ca...6&cat=0&page=2
Step 3 = Unhook all of the other accessories from the Defender lighting system. It can't handle the load. Look into installing a Blue Sea fuse block. http://www2.expeditionexchange.com/f...8&d=1265678632
Old February 28th, 2011, 12:04 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Ban Dan for actually trying to help a brother out!!!!!
Ha ha
Nice assist Danny Boy.
legend in my own mind
Old February 28th, 2011, 12:26 PM
Fuse?
Old February 28th, 2011, 12:38 PM
partisanjager42
michael B. Lube
1994 Defender 90
Flipped all of he fuses ordered all new relays. Find out by friday!
------ Follow up post added February 28th, 2011 10:41 AM ------
But why the hell did putting a rely in the blank spot fry the switches?
Old February 28th, 2011, 12:54 PM
dchapman
Daniel Chapman
1999 D1
I really doubt it's a relay.
Go to this site and scroll down about 3/4 of the page, just below the ARB Fridge description. There, you can read the short answer about your problem.
http://www.expeditionexchange.com/arb/
Old February 28th, 2011, 03:57 PM
partisanjager42
michael B. Lube
1994 Defender 90
That makes sense, but the other systems effected, what abot those?
------ Follow up post added February 28th, 2011 01:58 PM ------
Oh the gas & oil gauges are dead too???
Old March 25th, 2011, 10:34 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
I put one in there thinking one was missing, it also blew everthing including the 30amp ignition under the hood. took out the center relay replaced the 30 amp and all was well
Mike, i called today
directionals won't work if the hazzards are not wired or the fuse to hazzards is blown
3rd low and BOOT IT
Old March 25th, 2011, 11:01 AM
Jimmy, was the guy you sold it to in CO a board member?
Don't know if you ever saw his ad on CL.
http://www.defendersource.com/forum/...ad.php?t=29599
Old March 25th, 2011, 02:57 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Originally Posted by rijosho View Post
Jimmy, was the guy you sold it to in CO a board member? NO
Don't know if you ever saw his ad on CL. If i knew he was flipping it i wouldn't have sold it to him
3rd low and BOOT IT
Old April 8th, 2011, 01:21 PM
Back on the market? Michael, were you able to get rid of it?
http://cgi.ebay.com/ebaymotors/RARE-...item3f08e0d250
ht
Adding Interior Lighting don Defender Technical Discussions 10 February 9th, 2011 12:48 AM
over head lighting matansas Defender Technical Discussions 0 April 9th, 2010 06:59 AM
Dim dash lighting chris snell Defender Technical Discussions 9 January 14th, 2009 07:22 PM
Instrument lighting shawnpalmer Defender Technical Discussions 1 October 17th, 2005 10:23 PM
intirior lighting Rover- Girl Defender Technical Discussions 1 October 14th, 2005 10:59 AM
