NRP EXhaust Install Instructions and/or pics - Defender Source
Old August 22nd, 2014, 09:19 AM
bradfordish's Avatar
bradfordish
Bradford
95 D90 SW #141
Having a nightmare install of my new NRP exhaust. The fitment seems to be off and the instructions Rovers North sent are a joke. 3 pictures and about 4 sentences. If anyone has better instructions, pics of their installed NRP, or is in the NOVA area and will let me come take a look at yours I'd greatly appreciate it.
Old August 22nd, 2014, 09:23 AM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Had similar issues on both of mine. Where are you getting hung up?
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old August 22nd, 2014, 09:28 AM
The Y pipe fitment alone will knock ten years off your life. Frankly it is one of the worst purchases I ever made. I keep moving it from truck to truck tho. It has lasted thru three so far and will go on the Texas truck when I get it here.
What exactly is the issue?
Old August 22nd, 2014, 09:29 AM
lordhelemt's Avatar
lordhelemt
Paul
If your getting hung up on the rear pipe try removing the rear wheel and dropping the suspension. That should give you enough room to clear everything back there
Old August 22nd, 2014, 09:31 AM
I put one on a customer 4.6 110 last winter. Used a stock y pipe but otherwise it was pretty straight forward. I remember I wasn't thrilled with the fit.
Old August 22nd, 2014, 09:42 AM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Not sure if RN redesigned the NRP exhaust for the 90, but my very old NRP exhaust fit perfectly. The mechanic even removed it when he installed a new magnaflow y-pipe on my 90 a number of months ago. By the way it sound good. On page 4 of 4 of your pic (other thread) the resonator should not touch the rear wheel/tire, so you should be able to snake the exhaust properly underneath the gas tank and the resonator should come out straight. See photos
Old August 22nd, 2014, 09:52 AM
bradfordish
Bradford
95 D90 SW #141
Originally Posted by o2batsea View Post
The Y pipe fitment alone will knock ten years off your life. Frankly it is one of the worst purchases I ever made. I keep moving it from truck to truck tho. It has lasted thru three so far and will go on the Texas truck when I get it here. What exactly is the issue?
The main issue is I cannot get any clearance between the rear wheel and the resonator and still get everything to line up back at the muffler.
ID:	101401   Click image for larger version
Old August 22nd, 2014, 11:37 AM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Attached sample photo
Old August 22nd, 2014, 11:46 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
For what its worth, changing Y-pipes will not make a bit of difference. I just replaced an OEM Y-pipe with the Magnaflow and the connection to the exhaust was in the exact same place.
Old August 22nd, 2014, 12:08 PM
bradfordish
Bradford
95 D90 SW #141
Good to know Russel. I was starting to question whether that could be part of the issue as well.
Thanks Lee
Old August 22nd, 2014, 06:05 PM
bradfordish
Bradford
95 D90 SW #141
I got it in finally, and although a very frustrating process, I'm Very happy with the sound, or lack thereof. Still has a growl, but no more drone! Thanks for the help guys!
Old August 22nd, 2014, 06:39 PM
woohoo, nice!
Old August 22nd, 2014, 06:41 PM
pics?
Old August 23rd, 2014, 08:43 PM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
Installed an NRP on NAS 93 D110 last Saturday. Longest part of the job was cutting off the pile of rust that was on from new. Only problem I had was fishing the rear piece through. I had to jack up the body using a Hi-Lift in the trailer hitch receiver. Sounds great.
Old August 23rd, 2014, 09:06 PM
Exhausts don't go on unless the back is jacked up.
Old August 24th, 2014, 06:49 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Ok Brad, you know what I'm gonna ask...
Video? With Dolby surround sound please.
Old August 25th, 2014, 09:53 AM
bradfordish
Bradford
95 D90 SW #141
Before with the Magnaflow and then after with the NRP
Old October 24th, 2015, 03:13 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Thread resurrection....
I'm having issues with my NRP install. It's on a RRC w/ 3.5 but I think the Ypipe is the same for most V8s & models. I'm actually replacing a 15 yr old NRP system which fit fine on both RRC.
Currently I can not get the Y pipe to line up. Got it in place & the left side landed perfect on the manifold. Put nuts on loose & went to the right side. Could not get the studs to drop in the holes. Felt like the top of the Y had to rotate counter clockwise when looking down on it.
I on bolted the left side & still could not get it. Dropped the right manifold & attached to Y and it fits. Now I can't get the manifold back on. The rear of the manifold is against the head & the front is about an inch or more away.
If it matters, the Y is not attached to the rear section.
I'm stumped!..... and having a bourbon.
Thanks in advance.
Old October 24th, 2015, 03:55 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Tried again but the manifold still will not line up cause the cat hits the frame rail and if it did then the left side will be off. I thought I could force it but it's not looking good.
ID:	133079   Click image for larger version
Old October 24th, 2015, 05:18 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
I'd get all those manifold bolts threaded in about 75%. Then offer up the Y-pipe and make the connection at the downpipe. Maybe use a ratchet strap ro gently squeeze the Y-pipe if needed.
exhaust studs. NRP install d110pickup Defender Technical Discussions 5 July 16th, 2012 07:35 PM
NRP Y-Pipe and Borla Cat Back Exhaust Paul Grant For Sale - Parts 1 March 11th, 2012 12:50 PM
FS '97 D90 Y pipe and NRP exhaust ECR For Sale - Parts 6 November 29th, 2007 09:55 AM
NRP exhaust hanger Grover Defender Technical Discussions 8 May 14th, 2007 08:47 PM
NRP COMPLETE Exhaust for '97 OBDII D90 dmarchand For Sale - Parts 9 September 30th, 2004 09:07 AM
