NRP EXhaust Install Instructions and/or pics - Page 2 - Defender Source
Old October 24th, 2015, 08:20 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
That's more or less how I started minus the ratchet strap. The front & outside holes would line while the inside would be out of position. It's like one of the flanges is rotated just enough to make it a PITA. According to RN's instruction sheet, the two center bolt holes are the proper distance apart and the other two are about 1/4'' short causing a rotation off axis that cannot be forced into place. I'll measure my old NRP just to confirm tomorrow.
Old October 28th, 2015, 03:58 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Update....
Zack @ RN set out a new Y pipe and it installed with no problem.
Old October 28th, 2015, 04:56 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Your avatar shows an 88 County and you mentioned that it was a 3.5. Did you opt for the later y-pipe that hangs below the later crossmember, or does your y-pipe go over the cross?
Email is
Same place, new dogs.
Old October 28th, 2015, 06:55 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
You are correct, it's on an 88 RRC w/ 3.5. I was replacing an old NRP so already had the new crossmember... y-pipe hangs below.
exhaust studs. NRP install d110pickup Defender Technical Discussions 5 July 16th, 2012 07:35 PM
NRP Y-Pipe and Borla Cat Back Exhaust Paul Grant For Sale - Parts 1 March 11th, 2012 12:50 PM
FS '97 D90 Y pipe and NRP exhaust ECR For Sale - Parts 6 November 29th, 2007 09:55 AM
NRP exhaust hanger Grover Defender Technical Discussions 8 May 14th, 2007 08:47 PM
NRP COMPLETE Exhaust for '97 OBDII D90 dmarchand For Sale - Parts 9 September 30th, 2004 09:07 AM
