now idles high?? - Defender Source
Old September 20th, 2015, 01:37 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
now idles high??
Recently truck (95 D90 NAS stock) has had an intermittent idle issue whereby it starts normally then idle drops, never dies, and then back to normal. Truck runs perfectly after that.
Yesterday I replaced the three hoses and restrictor T section. Now it idles high. No vacuum leaks that I can discern. Could this have caused any issues?
I'm going to clean air idle control valve but wouldn't mind a few step by step instructions. I've searched but all solutions simply state; "Clean air idle control valve with carb cleaner and toothbrush".
I'm going to need something a bit more specific starting with its location
Thanks Board!!
KCD
Attributed to Shayne...
Old September 20th, 2015, 01:45 PM
its on the left hand side of the plenum at the back. you can't miss it!
Idle should be solved by AICV ... if it doesn't then next thing to check is throttle cable being too tight or timing
Old September 20th, 2015, 02:18 PM
IMO, best to go through the troubleshooting guide than to just attack random bits. Maybe the valve sticking is the problem. Maybe the base idle is set to high. Maybe one of a few sensors is not working problem.
RRC workshop manual has a great step by step guide to check each item.
Old September 20th, 2015, 02:24 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Originally Posted by kevincdoyle View Post
Now it idles high.
How high?
...and if I recall correctly, UD pointed out something in recent months about the possibility that "running rich" is or can be a symptom of an exhaust leak. Not that I'm really qualified to equate "running rich" & "idles high".
So, just to really hang myself out there, maybe the leaky hoses that you replaced were compensating for some other problem such as an exhaust leak? Anyone?
Old September 20th, 2015, 02:52 PM
Mine idled high because the timing was set incorrectly. There are a number of causes and so a methodical approach is best to ensure you don't miss anything.
Old September 20th, 2015, 05:00 PM
kevincdoyle
Kevin C. Doyle
Originally Posted by cowboy View Post
How high?
About 1100 give or take...
And they weren't leaking, I was just spiffing up engine bay with new stuff....
Old September 20th, 2015, 05:13 PM
kevincdoyle
Kevin C. Doyle
About 1100 give or take... And they weren't leaking, I was just spiffing up engine bay with new stuff....
Just double checking...
Old September 20th, 2015, 05:53 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Yes, that is it on the right with the wires you can see coming out of it.
Old September 20th, 2015, 06:03 PM
kevincdoyle
Kevin C. Doyle
Wish me luck boys....I'm going in as drink is chilling and charcoal is heating....
Old September 20th, 2015, 06:35 PM
kevincdoyle
Kevin C. Doyle
OK quick question..
Got the valve out and cleaned up, looked pretty clean actually...
my question is, should I be able to push the valve part in or pull it out when it is off the truck?
In other words, the valve will absolutely not move, in or out.
Is it controlled by the inner workings or should I just grab another one?
Thanks Board!
KCD
Old September 20th, 2015, 07:36 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
It won't go manually without a lot of force and I don't like to force mine. Just plug it into the harness and have some one turn the ignition on and off and you should see it extend and retract.
Old September 20th, 2015, 07:51 PM
kevincdoyle
Kevin C. Doyle
Thanks!!
to Jason and Chris and the others!!
Turned out super easy to do with a bit of guidance.
Pulled the idle air control valve, cleaned it with carb cleaner and wife's toothbrush and after a restart,truck is back to running perfectly.
If anyone is having trouble with idle, I highly recommend this 5 minute effort. My only issue was it was on there REALLY tight so it took some oomph to remove it.
Thanks again guys!!
KCD
Old September 21st, 2015, 08:15 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
Thanks again guys!!
KCD
Kevin mine sticks just as high on idle more often than not so thanks for posting this issue. Question I haven't looked at mine yet but how does it come off? Is it threaded on or just pull off/outward?
Thanks!
Will
Old September 21st, 2015, 08:50 PM
kevincdoyle
Kevin C. Doyle
Will- It just unscrews. Not sure of the size. Lefty loosey, righty tighty... I had to PM Jason because I was putting a LOT into trying to loosen it with no luck. He assured me probably it was just a bit of corrosion and to keep at it. Which I did and it finally broke loose. Might try a little PB or something first. Anyway like I said, kitchen table, carb cleaner, toothbrush and all better.
KCD
Also, to pull off the electrical connection which is in there pretty tightly and which you do first, make sure you release the underside of the clip first. It then just wiggles out. (that's what she said)
KCD
Old September 21st, 2015, 09:52 PM
ezzzzzzz
Mark Garrenton
This is a stepper motor. Never force it to move or it will break. I've also seen these fail when overzealous use of cleaner is applied causing the spindle to seize. I use an IAC found on any mid 90's Chevy Vortec V6 for replacement. Cheap, plentiful and it works fine. Grab a couple of clean ones at the junkyard for quick spares.
idle
200tdi Replaced nozzles idles rough Tribe Defender Technical Discussions 12 August 27th, 2015 09:48 AM
So now that Dash Bezel is NLA, what are we to do now? Neil McCauley Misc. Chit-Chat 7 October 9th, 2009 07:51 PM
High Lift Jacks on Sale RN Free Ship -NOW Shake For Sale - Parts 3 February 25th, 2007 06:30 PM
High lift mount! TwisteD90 Misc. Chit-Chat 10 December 15th, 2003 02:35 PM
high revs milli Defender Technical Discussions 5 December 12th, 2003 09:08 AM
