now... a loud squealing noise... - Defender Source
Old May 3rd, 2005, 08:31 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
I just put 'er back together after changing the water pump that finally came in, and the good thing is, is that it doesn't leak a drop, but the BAD news is that there is this loud howling noise coming from the engine. (belt ?... I've searched and read about the soap thing but haven't tried it yet, and it ran fine before except for the water pump leaking... and I'm wondering if I maybe got some grease on them ?... don't know)...
All my fluids are good, the belts are tight, I believe I put everything back together properly, but the noise is damn loud and it won't go away...
Any ideas ?
Thanks in advance.
Nicholas Orros
Old May 3rd, 2005, 08:50 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
wet belts can scream like a banshee, did you change the belt or is the same as before?
Could also be too much, or too little, tension on one of the belts.
-Hans
My oil line fix
My 100k stopped odometer fix
Old May 3rd, 2005, 09:58 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Hans,
Thank you for the input... Yes I believe I either wet the belt or got some grease on it.
I did the soap trick... About 1/3 bar of Lever 2000 and that cleared it up.
Finally... I have my D running !
Now onto the next phase of maintenance... The transfer case output seal, but from what I hear it's not so bad.
Thanks again.
Nicholas
Help! LOUD fan noise! proulx70 Defender Technical Discussions 4 August 20th, 2007 09:07 AM
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
LT230 noise? Chaucer Misc. Chit-Chat 5 March 19th, 2005 02:59 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
