Went to change in the oil in my LT230 and found a big chunk of metal stuck to the magnet on the drain plug. Pulled the bottom cover to inspect and find many more.
I am pretty sure it is remnants of a broken shim or washer behind the last gear towards the back of the case. See photo where I circled it.
So what is this part? Truck seems to be running fine with no chunking or grinding etc... only a gear whine I seem to notice more nowadays. Obviously this is not good and I need to address it. So what is the best solution? New t-case, rebuilt one? Worth trying to tackle it and replace it? How does this sort of thing break?
What will happen when and if that "shim" gives way completely?
Who knows why it failed. Doesn't matter why it failed (defect in shim or plain misfortune), its compromised. Worth picking up a used LT230 give how cheap they are.
I wouldn't care being stranded off road. Being stranded in NYC is a nightmare. There is only one tow company allowed to tow you off of the highways and they won't tow you any further. I was charged $140 to be towed 150 yards off of the highway to be left in a no parking zone. I then had to wait for the second tow truck to get me there and tow me to the dealership.
Breaking down off road isn't a big deal in most cases since you likely have no where you have to be. Breaking down on your way to work and showing up at 11 AM sucks.
I actually like driving in traffic in NYC more than anywhere else because there are so many roads. If you get stuck in traffic in downtown Richmond, you have nowhere else to go.
From what I have read it looks like the '02 transfer boxes didn't even have the diff lock in the case and maybe '03 as well. '99-'01 had it in the case but not hooked up and then they brought it back in '04. Hard to say if the '02's will work.
I guess these parts you've found are parts of a taper bearing, because the shims are inside the bore, behind the outer rings.
Kurt
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
