Not so mystery Rheostat - Defender Source
Old May 2nd, 2016, 12:47 PM
Yorkie
Mark Whitehouse
1989 D90
So I was checking fluid levels on the 90 on Saturday and noticed a Rheostat type switch on the right hand side. Tried turning it to see what happened and the fans came on. So apart from making the fans come on what is the switch for and how should it be used?
This vehicle has taught me more in the 5 weeks that I have owned it than I have learned in the previous 30 years of owning vehicles!
Old May 2nd, 2016, 12:59 PM
It is most likely a Kenlowe fan controller. It adjusts the temperature that the fan turn on.
Thermo switch - Accessories for Kenlowe fan kits - Kenlowe fan kits - Cooling system - Tuning, internal and external fixtures - Warehouse - SC Parts Group Ltd
Old May 2nd, 2016, 01:19 PM
rovertrader's Avatar
rovertrader
Dale
Now be sure to get it set correctly before over heating...
Old May 2nd, 2016, 01:44 PM
Yorkie
Mark Whitehouse
1989 D90
How do you set it?
Old May 3rd, 2016, 02:54 AM
Originally Posted by Yorkie View Post
How do you set it?
first step is to never turn it ... They are factory set and adjusting it requires sending the vehicle back to kenlowe in the UK.
Old May 3rd, 2016, 06:15 AM
rovertrader
Dale
This, or use an infrared temp gun to monitor engine/radiator temp and set accordingly...
Old May 3rd, 2016, 07:47 AM
Oh good lord. Wait until you are at normal operating temperature with a nice hot upper house. Adjust until it comes on. Turn a bit until it just turns off.
Should be good. Keep an eye on it.
Don't do any deep wading as it is not waterproof. Their stuff is not the most robust.
Old May 3rd, 2016, 08:47 AM
Yorkie
Mark Whitehouse
1989 D90
Thanks John I know I'm a PITA being a complete newbie but you have always provided great advice!!
Old May 3rd, 2016, 08:58 AM
don't get put off by the hecklers and peanut gallery dwellers ... everyone here was a newbie once and we are all still learning about our vehicles.
Old May 3rd, 2016, 09:44 AM
One thing that is worth doing, IMO, if you use an electric fan, is to add a light somewhere on the dash that turns on when the fan is running. It is nice to know that it is running or not when you think it should be.
The "Oh good lord." comment was not directed to the OP.
Another Mystery Noise...well maybe not! Bill Larson Misc. Chit-Chat 13 October 1st, 2013 08:12 PM
Coolant leaking into cylinder mystery jaherring Defender Technical Discussions 9 April 17th, 2007 07:55 PM
Mystery Brake Lines cbass Defender Technical Discussions 9 January 29th, 2007 03:42 PM
Defender in Paris, and Mystery Guest Doug Misc. Chit-Chat 20 June 18th, 2004 01:52 PM
That mystery box by the gas tank. wicks Misc. Chit-Chat 7 April 2nd, 2004 07:43 PM
